Rear Suspension Clunking
  1. NightStalker
    NightStalker Member
    Oct 17, 2017
    Yellowknife, NWT
    2017 Civic SI
    Sounds like it's the same thing I was told. Most recently I've heard "New improved damper mounting base on both sides and insulate the damper cap with EPT foam".
    Fun fact, the doors don't close well when its -38c :)..... Fingers crossed though.
  2. TheComebackKid
    TheComebackKid Senior Member
    Sep 22, 2017
    195
    109
    Montréal, Québec
    Nick
    2017 MSM Civic Si Sedan
    -10c/14f this morning and no clunking like I had the 2 other winters. No parts changed...
  3. 2112
    2112 Senior Member
    Jan 31, 2017
    278
    299
    Cleveland, Ohio
    2017 Honda Civic Type R #00969 BLK, 2015 Nissan 370Z Roadster (BLK), 2019 Civic Si Modern Steel Metalic
    Can you get more detail specifics on the part numbers they ordered? Curious if this is consistent with the parts mentioned earlier in this thread as resolving the issue. 52670-TBF-A11
  4. R MODE
    R MODE Senior Member
    Oct 9, 2019
    76
    98
    Phoenix Arizona
    Rick
    2019 Civic Type R Championship White
    Man, it has been really really cold this year. When I left for work at 7:30 this morning it was 48 F !
    Holy cow, the high today is only 60 F !
    Living in Phoenix is a hardship I tell ya. I shall somehow persevere!
    Back on topic, I don't hear any clunking noise.
  5. 2112
    2112 Senior Member
    Jan 31, 2017
    278
    299
    Cleveland, Ohio
    Maybe if you had a SI you might hear the clunking and if you lived in a colder climate. Type R's are not being reported as having the clunking noise anyway. Sorry, you are in the wrong forum.
  6. CLnet2014
    CLnet2014 Senior Member
    Jun 28, 2018
    65
    39
    Montreal
    Honda Civic SI 2018 Coupe
    Hello,
    Im bringing up this thread again, since i have good news for all of you guys.
    I got the confirmation by Honda Canada that they finally came out with a second "attempt" to fix their suspension noise when its cold during winter.
    New service bulletin #B-1-19 ( You actually need to ask for it, since this is not a recall, customer that have rear suspension noise can ask for this bulletin )
    This change consist of installing new Top Plate on both shocks, and adding some kind of isolation between the top plate and the "cover" of that top plate. For both sides.
    I got one friend of mine that did it. Its winter here and so far, after two weeks, no more noise.
    I will do this bulletin and let you guys know.
    Cheer :)
  7. OP
    Spacesloth
    Spacesloth Senior Member
    Oct 18, 2017
    58
    Wisconsin
    2017 Honda Civic SI
    Would it be possible for you to get a copy/pictures of the TSB for us in the USA since Honda seems to be omitting us. That way we can do it ourselves.
  8. CLnet2014
    Jun 28, 2018
    65
    39
    Montreal
    I'll try to get my hands on those documents.
    But in any way, if you have rear suspension noise, you could technically just show up at the dealer and tell them that there's a new TSB.
    They won't deny it.
  9. OP
    Spacesloth
    Oct 18, 2017
    58
    Wisconsin
    2017 Honda Civic SI
    Unfortunately Honda USA does not recognize Honda Canada TSBs, I got the run around even after bringing the first TSB for this issue after it came out.
  10. dpalce19
    dpalce19 New Member
    Dec 16, 2019
    Winnipeg
    Dary
    2019 Civic SI sedan
    What if they do? I called Honda Canada and a representative could not find that TSB number and said I should get the dealer to call Honda Canada directly and have them look for it....
  11. CLnet2014
    Jun 28, 2018
    65
    39
    Montreal
    Ah thats strange...
    You should just deal with your dealership at this point.
    I just know that its out, a friend of mine did it last December 6th.
  12. Bastien.E
    Bastien.E New Member
    Dec 8, 2019
    Winnipeg, Manitoba, Canada
    Fritz Bastien
    '19 Honda Civic SI sedan
    Sorry I asked both my dealer and honda canada about tsb number or even just bulletin pictures and they all said they are not allowed to giveout such info
  13. NightStalker
    NightStalker Member
    Oct 17, 2017
    Yellowknife, NWT
    2017 Civic SI
    Had the work done.
    I still hear the noise, albeit its much less obvious than it was before and I have gone over some bumps expecting to hear it but got nothing.
    Something to note, it is -43C here so we're talking a fairly extreme side of the spectrum temperature wise. I will keep driving it and see if anything changes, maybe when temperatures stabilize eventually it will completely go away, if that's the case then I'll report back.
    Something interesting to note, the picture below is the old mount, its cracked. Fun times :).
  14. ZEEE Man
    ZEEE Man Member
    Dec 14, 2018
    SK, Canada
    2018 Civic SI, 72 Z-28
    Well that pic there just might be the answer to this whole thread. With that collar cracked through, the shaft from the shock would have just enough play to make the noise we are hearing, plus you can see that the nut/washer has been wearing into that collar from the extra movement. I'm getting this done as well this month when the parts arrive so it will be interesting if mine is the same way. Thanks for the pic NightStalker!
  15. TheComebackKid
    Sep 22, 2017
    195
    109
    Montréal, Québec
    Nick
    #315 TheComebackKid, Jan 13, 2020
    I was just at the dealership today for an unrelated problem and I brought up the new tsb for the clunking to the service advisor. He ordered the parts and should take 2 weeks to get. I'll update once the fix is done.
