Rear of the car rock, bounce, sway side to side after brake fluid flush job
  1. raymondmit
    raymondmit Member
    Feb 22, 2018
    Honda Civic EX
    Hello guys,
    I recently flushed the brake fluid by myself.
    But after that, I noticed that the rear of the car rock, bounce and sway side to side.
    I first noticed it on the highway when a sudden shift to the right and back. then it became more of a side to side thing.
    Does it have to do with the brake line with air bubbles? or it is something else.
  2. Fanoflive
    Fanoflive Senior Member
    Apr 2, 2017
    458
    409
    Belvidere IL
    Jeremiah
    2017 Honda Civic Coupe EXT 6MT
    I am not an experienced mechanic but I would say to look at the rear sway bar and end links. The brake fluid should have nothing to do with the handling of the car.
    raymondmit thanked this.
  3. NHCivicGuy
    NHCivicGuy Senior Member
    Oct 10, 2018
    719
    398
    NH
    2019 Si
    I'm assuming the wheels were removed from the car. I would check to make sure the lugs are torqued down properly.
    raymondmit, civicls and shoegazer thanked this.
  4. lexro
    lexro Senior Member
    Feb 28, 2019
    63
    Montreal
    Civic LX 2006, Civic Sedan Sport 2019
    are you suggesting a loose wheel? that sounds terrifying af.
  5. OP
    raymondmit
    raymondmit Member
    Feb 22, 2018
    Honda Civic EX
    Would it be possible to be caused by calipers being stuck to that the friction of the pad made the pulling?
  6. NHCivicGuy
    Oct 10, 2018
    719
    398
    NH
    2019 Si
    Yes, happened to two people I know, both almost lost it on the highway doing 80.. never trusted Sears Auto.
    Yes it can.
  7. charleswrivers
    charleswrivers Senior Member
    Nov 3, 2017
    2,587
    2,714
    Occupation:
    EMNCS(SS)
    Kingsland, GA
    Charles
    '14 Odyssey EX-L '18 Civic SI Sedan '94 300zx twin turbo 2001 Ford F-150 Sport
    X2 on checking the lugnuts tight. It's the one thing you definitely disturbed. The mentioned suspension components next.
    The only other thing I'd add that hasn't been mentioned, look at your rear shocks. One time, albeit on an older car, I randomly had a shock absorber fail when it was jacked up. I'd look at that too... mainly by looking and seeing is there's oil leaking around the shaft of the shock. If it still seems ok, you know your end links are tight and lug nuts are tight, but you go over a speed bump and the rear end is unsorted, I'd still think the dampener is suspect. It is pretty unlikely though... especially on a newer car.
  8. civicls
    civicls Senior Member
    Aug 8, 2018
    922
    422
    Upstate NY
    2017 Honda Civic EX-T, 18' Odyssey Elite, 07' Sienna
    This can also happen with air still in the lines of one caliper, but that's in the extreme case of loss of brakes on one side of the wheel. Vehicle will "pull" to the right or left. But I'm guessing yours has to do with the wheel.
    Make sure their torqued to 92 lbs ft. Get a 20 buck torque wrench from Harbor Frright it's well worth it...
