4drsiblue
Depends on your clutch too. I’ve had different stages of clutch and mounts stiffness and I can tell you one thing after it’s broken in it’s not so bad. 62a to me is to soft to handle anything and 70a is just right there. I think boombaracing is at the sweet spot at 80 durometer bushing. With hasport your either 70 or 88.Would this help to reduce the bouncing effect that I get when letting off the throttle abruptly in low gear? With the KTuner rev hang delete enabled, the threshold for going from part throttle to no throttle can be somewhat abrupt and jarring, and often results in the car bouncing forward and back gently a few times (even when I attempt to transition off gradually).
