Rear Motor Mount – CVT – Boomba Racing
  1. Boomba Racing
    Boomba Racing Civic X Vendor
    Nov 30, 2016
    689
    417
    Wood Dale, IL
    2017 Civic Sport, 2018 Civic Type-R, 2010 Civic SI, 2015 Civic SI,
    #1 Boomba Racing, Dec 29, 2016
    Available now!
    Link to buy: https://www.boombaracing.com/2016-honda-civic-rear-motor-mount-cvt/
    Install guide: https://www.boombaracing.com/content/CIVIC X - MOTOR MOUNT MANUAL.pdf
    --------------------------------------------ORIGINAL POST--------------------------------------------
    Boomba is no stranger when it comes to motor mounts for Honda Civics. We’ve made mounts for the European Type-R’s, R18’s, 8th Gen & 9th Gen Civics in the past. Now we are looking to expand with the tenth generation Civic.
    You may be questioning “what is a rear motor mount” or “why do I need to replace my rear motor mount?”. Let us educate you a little bit on that matter.
    A rear motor mount secures your engine to the subframe. From the factory these mounts are fine for normal driving but often leave a lot to be desired in the terms of performance. Stock mounts are sloppy and result in a lot of flex. This gives you undesirable things such as wheel spin, torque steer, and wheel hop.
    The Boomba Racing Motor Mounts feature a poured in polyurethane bushing rather than a pressed in one. The benefits of this can be seen here in this video:
    I’ve attached a picture of our in-development mount below!
    These are set to release very soon.
    Let us know if you have any questions.
    NeoDragons and stak thanked this.
  2. hawk02
    hawk02 Senior Member
    Nov 3, 2016
    1,235
    568
    Far away
    2017 Civic Si Coupe
    Looks great!!!!
  3. OP
    Boomba Racing
    Nov 30, 2016
    689
    417
    Wood Dale, IL
    Thanks! We can't wait to get these released!
  4. RallyeRed
    RallyeRed Senior Member
    Nov 21, 2015
    426
    255
    Occupation:
    DCTS Build Technician
    Gilbert, AZ
    2016 Honda Civic Touring
    How much will these cost? Also, does this fix how jumpy the car is at low speeds?
    Also, what is the rating on the poly? Would this mount be okay for a daily driver?
  5. OP
    Boomba Racing
    Nov 30, 2016
    689
    417
    Wood Dale, IL
    This should eliminate a lot of the jumpiness.
    We are using a 80 durometer bushing in this mount.
    This will be suitable to use on a daily driver. Any aftermarket mount will add a little bit of NVH (noise vibration harshness) but our mounts significantly break in after the first 1,000 miles.
    RallyeRed and hawk02 thanked this.
  6. RallyeRed
    Nov 21, 2015
    426
    255
    Occupation:
    Gilbert, AZ
    Would you say that the durometer rating goes down after it breaks in?
  7. jeffbatt
    jeffbatt Senior Member
    Oct 1, 2016
    150
    Boise, ID
    2016 Civic Touring Sedan, 2000 S2000
    Would you consider making a hard rubber version as well?
  8. OP
    Boomba Racing
    Nov 30, 2016
    689
    417
    Wood Dale, IL
    You can say it feels like a lesser durometer once it breaks in, but the mount is still the same amount effective.
    In terms of comfort goes, you wouldn't really want anything harder than this.
  9. jeffbatt
    Oct 1, 2016
    150
    Boise, ID
    By hard rubber, I meant slightly stiffer than stock but softer than poly. In a previous car I used a poly mount and it was way too stiff for me.
    Thanks!
    ard
  10. OP
    Boomba Racing
    Nov 30, 2016
    689
    417
    Wood Dale, IL
    I can forward the idea along to our engineers. Typically we stick to polyurethane when it comes to our mounts. Not all mounts using poly are created equal, either.
    jeffbatt thanked this.
  11. hawk02
    Nov 3, 2016
    1,235
    568
    Far away
    2017 Civic Si Coupe
    Will you be doing a complete mount kit or just the rear?
  12. jeffbatt
    Oct 1, 2016
    150
    Boise, ID
    Thanks!
    Your mount looks fantastic by the way.
  13. OP
    Boomba Racing
    Nov 30, 2016
    689
    417
    Wood Dale, IL
    We plan to only begin with the rear mount first and expand if there is more interest in other mounts. Just this single mount alone really transforms the car.
    We should have some more updated pictures today!
  14. RallyeRed
    Nov 21, 2015
    426
    255
    Occupation:
    Gilbert, AZ
    How does your mount compare with the Hasport mount that starts at a durometer rating of 62? Wouldn't your mount be much stiffer for every day use?
  15. OP
    Boomba Racing
    Nov 30, 2016
    689
    417
    Wood Dale, IL
    A mount can't be judged strictly on its durometer rating. The design of the mount also plays largely into how stiff a mount actually feels.
    RallyeRed thanked this.
