Rattle Under Light Load
Tags:
  1. Johneeeh
    Johneeeh Member
    Apr 15, 2018
    Honda Civic EX-T
    Hello Folks,
    I have been dealing with a rattle somewhere in my Civic for the last year, the dealership is unable to find the source of the noise after bringing the car to them about 5 times to investigate.
    The noise only happens when the engine is warm enough to idle around 600RPM, and it only occurs in drive (not park, not reverse).
    Have any of you ever experience this noise? Or would you have any clue what it could be coming from? The dealer changed one of the engine mounts, adjusted the exhaust, tighten the floor panels. The car doesn’t idle rough, but the light load on the engine is enough for something to make the noise.
  2. SDAlexander8
    SDAlexander8 Senior Member
    Jul 11, 2019
    647
    435
    Occupation:
    Environmental
    Indianapolis, IN
    Steve
    2017 Civic Si Coupe
    #2 SDAlexander8, Nov 5, 2019
    I had this rattle in my LX that I put 60k miles on. Only when put in drive while still in my parking spot.
    This car makes many strange sounds.
    Edit after watching your video: that’s way worse than my LX was. That sounds like something is broken or not being held in place correctly. Get your dealership to figure that out.
  3. KnoxTn17Si
    KnoxTn17Si Senior Member
    Apr 30, 2017
    638
    722
    Occupation:
    CNC II Setup/Programmer
    Knoxville Tn
    2017 Si sedan
    When it's making this noise, can you barely rev it and the noise goes away? When the rpms drop back down, does the noise come back? Does it sound like it's coming from the driver side of the car?
  4. OP
    Johneeeh
    Johneeeh Member
    Apr 15, 2018
    Honda Civic EX-T
    Yes, as soon as it revs above idle it goes away. It is really hard to tell where the sound comes from, thats why i move the camera around in the video. It sounds similar from both sides.
  5. KnoxTn17Si
    Apr 30, 2017
    638
    722
    Occupation:
    Knoxville Tn
    2017 Si sedan
    Mine just started making that sound. Almost sounds like it's coming from the dash area. I know once I drive and get to work or home, it doesn't make the noise anymore. So weird....
  6. shoegazer
    shoegazer assistant to the assistant manager
    Sep 5, 2018
    573
    275
    Raleigh NC
    2018 Civic LX Coupe 2.0 (CVT)
    I've just noticed this happening in my LX. It's not as loud. And it seems to be coming from the gear shifter/selector area. But it also just started just as the weather broke and turned much cooler.
    I believe it's just a mechanical resonance.
  7. KnoxTn17Si
    Apr 30, 2017
    638
    722
    Occupation:
    Knoxville Tn
    2017 Si sedan
    I will say it didn't make the noise at all today. The 3 days it did, the temps were in the low 30's. Today mid 60's low in 50's. Gotta love Tennessee whether.
  8. OP
    Johneeeh
    Johneeeh Member
    Apr 15, 2018
    Honda Civic EX-T
    Yeah the noise seems to be more evident during the colder months. On hot summer days it usually doesnt make a noise.
  9. Edd
    Edd Senior Member
    Mar 18, 2019
    68
    Occupation:
    Professional Critic
    Sactown 'burbs, CA
    Edd
    2019 Civic EX sedan
    How about the hood?
    My Tacoma had a similar vibration rattle, with same symptoms as yours.
    Turns out, it was a missing rubber bushing that apparently fell out. Replaced it. Sound gone.
    Next time, open the hood (while it''s running and making noise) and see if the noise stops.
