Rattle list
Tags:
  1. d1390
    d1390 Senior Member
    Jun 15, 2017
    278
    86
    Australia
    FK8
    #1 d1390, Aug 12, 2018
    Hi guys,
    I thought that I should compile a list of different rattles and a fix for each. I got quite a few and hoping someone would know on how to resolve them. Here I go:
    - driver side A pillar: can replicate this by reving to 3k rpm and let it drop at around 2.5k or 2k rpm. Can hear metal frame in there buzzing?
    - this one is next to you somewhere around the seatbelt over your shoulder when going over bumpy, roads can't figure this one out.
    - this one is somewhere around the shift area sounds like plastic. Can replicate it when reving slightly or pulling out/reversing out slowly from a stop.
    -this one is annoying. Rolling the window down half way or slightly. Going over bumps will make the window rattle against the rubber.
    Anyone experience any of these?
    bobafettm thanked this.
  2. haojohn
    haojohn Senior Member
    Feb 21, 2017
    79
    42
    Houston, Tx
    2018 Civic Type R PMM
    I have overhead console rattle very slightly sometimes.
  3. OP
    d1390
    d1390 Senior Member
    Jun 15, 2017
    278
    86
    Australia
    FK8
    yeah same, do you have climate circulation turned on when this happens?
  4. TheBigG
    TheBigG Senior Member
    Oct 24, 2017
    238
    117
    Sweden
    Gabriel
    Civic Type R 2017, Kia Optima Sportswagon GT 2017
    - in the middle of the dash or a little bit to the right. It feels inside of the dash. Will appear at exactly 2000 rpm. It feels stronger when cold (winter time)
    Gansan thanked this.
  5. sean465
    sean465 Senior Member
    Apr 26, 2017
    169
    112
    London
    Championship White Civic Type R FK8 R-03927
    I have the first 3 in your list
    A pillar, someone on UK forum disconnect battery to avoid airbags going off and took the trim off and padded it out with foam, job done
    Central one could be the central speaker. fixed under warranty, some were missing plastic clips
    Ive got used to them now though and must subconsciously block them out!
  6. OP
    d1390
    d1390 Senior Member
    Jun 15, 2017
    278
    86
    Australia
    FK8
    - With the pillar ones, if i rev high while driving both pillars will vibrate like crazy. I think it is the actual metal frame that vibrates rather than the plastic.
    - the one with the seat belt, I found out it must not be the seat belt at all but rather the rear passenger windows. To replicate you can knock lightly around the window when it is up until you hear a slight difference in sound. I think this is what rattles when going over rough roads.
    - the one around the shift knob I managed to take a closer listen, and it sounds like its inside, nothing you can fix from outside.
    Might have to take it on my next service to check it out. Only worried that it will take too long and they will thrash it to replicate it each time :(
  7. Lust
    Lust Senior Member
    Apr 17, 2018
    326
    219
    Bay Area
    Michael
    2019 Champ White Type R
    I'm getting a metallic rattling noise when in high RPM. I do have E-Man's modified CMC which does add some NVH. It's hard to tell if the rattling noise is coming from the CMC itself or something else that is loose or something vibrating against each other. The rattling is pretty easy to replicate and will go away once I push the clutch in.
  8. 9000RPM
    9000RPM Senior Member
    Feb 19, 2017
    153
    126
    New Jersey
    '18 CTR // '14 Cayenne
    check the tweeter mesh piece. 3 of mine are loose. the 2 rear ones are bad and I hear them rattle all the time. My front driver side is a little bit loose but it never rattles.
    HaRDYSi925 and bobafettm thanked this.
  9. bobafettm
    bobafettm Senior Member
    Jan 8, 2017
    686
    783
    Metro Detroit, MI
    2006 Lotus Exige & 2018 Honda Civic Type R
    I definitely have the wind issue and the tweeter rattle.
    Although mine is not the shift as much as it's the upper plastic that holds the shifter boot, type R button, etc... If you pull up or down on that while hitting bumps = zero rattle.
    I think it's time to bust out the good old british car fixes! double sided felt and scissors lol... My Exige is covered in that shit.
    d1390 thanked this.
  10. HaRDYSi925
    HaRDYSi925 Member
    Apr 3, 2019
    41
    Concord CA
    2019 Honda Civic SI
    When I bought it brand new the center armrest and storage area would not stop making a cracking sound probably for at least the first 300-400 miles. it drove me crazy because a lot of times I like to drive with the radio off and just enjoy the sounds of my car. But that crackling sound drove me nuts I'm so glad it's gone I just thought since it's a brand new car its still just breaking in the plastics.
  11. OP
    d1390
    d1390 Senior Member
    Jun 15, 2017
    278
    86
    Australia
    FK8
    Yeah this, when turning on the car and the RPM drops you hear slight rattle around that area where the R buttons are. I tried to hold it down or budge it to a position where it would stop. I think that entire plastic shroud that hold the shifter sits on top of the arm rest and it rattles together by the looks of it.
  12. bobafettm
    Jan 8, 2017
    686
    783
    Metro Detroit, MI
  13. Wabby
    Wabby Senior Member
    Dec 14, 2016
    294
    298
    Norway
    Honda Cr-z
    I have the same one. Also my ventilation makes a sound that follows the rpm...
  14. 18TypeR-13922
    18TypeR-13922 Senior Member
    Jul 17, 2018
    111
    76
    Philadelphia
    ADM
    2018 CBP CTR, 2013 CBP Pilot Touring, 2015 Accord EX-L
    At 3000 rpm behind the infotainment screen, worse when its cold outside. Wonder if there's a connector or something behind there that needs to be wrapped in foam.
  15. tinyman392
    tinyman392 Senior Member
    May 21, 2018
    1,071
    547
    Illinois
    Marcus
    '18 Civic Type R (RR)
    I only have one rattle/sound when I am drive from the steering column area and only when it’s cold. The rest have been stuff in my glove box and the sunglasses I Store in the driver side grab handle. I guess I’m very lucky. Haha
