R intercooler in a non-R
charleswrivers
Charles
Kingsland, GA
Anyone ever swap a...
http://hondapartsnetwork.com/part/9703626/Honda-Part-19710-5AA-A01-Intercooler
For a...
http://hondapartsnetwork.com/part/9767457/Honda-Part-19710-5BF-A01-Intercooler
...Same car... but obviously *vastly* different dimensions.
How about a...
It'd be from an Accord. Cheaper. A lot of size still.
I'm used to cobbling together Intercoolers. In my Z31 days, we didn't have an intercooler stock and we were getting old Starion or Supra OEM Intercoolers, a lot of ducting and making it work.
At ~$100 a pop for a intercooler with more internal volume (I know extra lag would be a unwanted size effect) but a larger surface area on the face for heat exchanger... these look to be a steal.
There was a WTB thread that got me thinking. I know there are some outstanding aftermarket options, but the OEM already has 2 Intercoolers made for Civics... and the R is sized for an engine that stock is about the equivalent power of the best tuned 1.5ts we've got.
charleswrivers
charleswrivers
Charles
Kingsland, GA
I did a look but didn't come up w/it. Thanks. I know you'd have to use different ducting or fab your own as it's dimensionally different.
callmehandsum
Studmuffin
L.A.
17 Civic Si, BMW 540i, Chevy Spark EV, Civic LX
Are you considering doing this? How hard would/could it be?
charleswrivers
charleswrivers
Charles
Kingsland, GA
If it was like the Z31s... you got whatever intercooler you could find, made it fit and got ducting to complete the circuit.
Since a type R and non-R are the same car... dimensionally it oughta fit, barring differences with the radiators or A/C components that w/the 1.5, might get in the way.
Not to over simplify how great a good intercooler can be... but it's just a hollow aluminum heat exchanger. As long as you can mount it, and hook ducting up to it and it has a source of airflow, it works... in the most crudest of senses.
There is obviously total crap ones out there. Going too big requires more air to pressurize the tract... raising lag. It can also hurt velocity, lower pressure, though if you have much lower IATs, the improved O2 content would counter this somewhat.
Again, there's a whole lot going into matching an intercooler with a car. We can see the stocker won't do well, but this is a lot on the turbo... as running much higher than stock boost make it just push hot air. A big intercooler for a little turbo is a bandaid.
With the (old) Z31 background I have... *any* intercooler was better than none as you went from their stock 6.7# and were getting much over 10#s. It just seemed like there was a big, cheap OEM intercooler available. If it mounted in the front of the radiator on the 1.5ts and you could fab some ducting then... well... boom. Big, cheap, new intercooler. I don't know that it would necessarily be a good match. I was just curious. Obviously, an aftermarket one that can use the stock ducting (though ducting can be very restrictive in itself... going from 2.0" ducts to 2.5" ducts in Z32s was *huge*) and stock mounting points will always be *very* easy.
http://www.twinturbo.net/nissan/300...-info-about-turbos-and-pipes-DYNO-CHARTS.html
One thing... the OEM one for the 1.5ts (all the same) shows the packaging dimensions as 36.5cm x 26.4cm x 17.5cm. No way. Its way longer than ~1ft.
The fact that the inlet/outlet is flanged would make it a bit more of a PITA and make you need to get the inlet and outlet pipe assemblies. Together, they're pretty much the cost of the R's intercooler itself.
charleswrivers
charleswrivers
Charles
Kingsland, GA
Actually... looking at the Accords, only 1 of 2 of the end tanks is flanged... and both the 1.5t and the 2.0t have an intercooler that weighs in at ~8 lbs and is roughly dimensionally the same.
1.5t... (It's $79)
http://hondapartsnetwork.com/part/9780300/Honda-Part-19710-6A0-A01-Intercooler
2.0t... ($315)
http://hondapartsnetwork.com/part/9787827/Honda-Part-19710-6B2-A01-Intercooler
The Rs intercooler... same *exact* shipped weight of the 1.5t Accord. End tanks look different though as you have to have 2 flanged pipes to hook it up.
Our little guy? 4.4 lbs. (...same as the CRV, though the part numbers are different... I think the end tanks are slightly different)
Other huge price difference... to get the single flange pipe you need for the Accord 1.5t's hot side... ~$12.
So we're <$100 for intercooler that is sized essentially the same as an Rs and for needed flange + intercooler to just go to regular charge piping (and I'm sure that's where you need to fab some little piece in, hopefully without too tight a turn to keep velocity up) There's also 'stay assemblies' (ie. brackets) that are about $5 each. for mounting...
*If* you could make it fit... it looks like you could get an intercooler dimensionally similar to a Type Rs (much larger than the 1.5s and the flange to just go to standard piping and brackets for a *smidge* over $100, not counting shipping.
Very interesting the Accords 1.5s get an intercooler with a similar dimension and capacity as the 2.0.
charleswrivers
charleswrivers
Charles
Kingsland, GA
Well... I've got to satisfy my curiosity... I'll be on travel one last time for my Squadron job and will be back next weekend. Maybe everything will be here by then.
I'll let y'all know how it goes. The only thing I'll have to find is some extra ducting to replace the Civic's flanged connections. The 'trim piece' that was discussed in some install videos I've seen on YouTube surrounding the intercooler isn't a 'trim piece' it's a duct to route airflow to it. There's a large amount of room behind the bumper from what it look like that that duct takes up. My Z32 had the same sort of thing on the stock intercoolers (they're SMICs on the Z32). When you replace them, you either forgo the duct, cut it to match the new one... or there are some brands (ie. Stillen) that makes replacement ducts specifically for theirs.
If it goes horribly wrong, or there's no way it'll work... I'll let y'all know too. I'm not too interested in chopping the bumper up to make it work. I'd love it if the Accord folks had a intercooler install video... or even something that shows the bumper removed but... it's not to be. The only thing I'm a little meh on is how the flanged connection on the passenger side it going to sit... and whether or not it takes an odd bend.
charleswrivers
charleswrivers
Charles
Kingsland, GA
Well, my ~$150 shipped worth of wrong intercooler and pieces/parts/connections have shipped. Here's hoping!
charleswrivers
charleswrivers
Charles
Kingsland, GA
Arrival is supposed to be 2/28. I'll take a picture or two, make some measurements so we can see what it's internal volume is and frontal face area is for comparison. I was hoping to have it this weekend and have plans next so it may take me a smidge to report back, but I'll let y'all know stuff as I can.
charleswrivers
charleswrivers
Charles
Kingsland, GA
Ok... got it in last night. Measurements today...
Front face surface is 28"x5"= 140 in^2
Volume 28"x5"x2.5" = 350in^3
I am just measuring where the fins start on the ends.
I'd greatly appreciate it if someone has removed a stock intercooler to take comparative measurements. The only thing I had to go by as a difference was weight... as this intercooler was roughly x2 heavier than the stock unit. Overall length, including end tanks is right at 3 ft.
Honda Civic 10th gen R intercooler in a non-R IMG_20180301_172722946
Honda Civic 10th gen R intercooler in a non-R IMG_20180301_172817923
Honda Civic 10th gen R intercooler in a non-R IMG_20180301_172825296
Yep... looks like an intercooler.
I have the bracket mount for the one side to go to a standard tube...
Honda Civic 10th gen R intercooler in a non-R IMG_20180301_173020883
...so that both sides can just go to regular old tubing that I'd have to experiment in what length/shapes to get to attach. Also got whatever gaskets/mounting hardware that we're part of the 1.5t Accord setup to attempt a mount. $161 shipped. If it turns out this unit isn't really bigger than stock, I'll chock it up as a loss and return and get my $$$ back minus shipping and restocking, but that looks to be, based on comparisons the biggest cheap intercooler made for the Civic/Accord platforms. At 2x the weight, I'm hopeful.
charleswrivers
charleswrivers
Charles
Kingsland, GA
Big thanks to @gylmar814 for providing measurements for a stock intercooler. The juice is not apparently worth the squeeze...
Stock (pictures provided by @gylmar814)
Honda Civic 10th gen R intercooler in a non-R 20180301_180312
Honda Civic 10th gen R intercooler in a non-R 20180301_180300
Honda Civic 10th gen R intercooler in a non-R 20180301_180243
vs Accord...
Honda Civic 10th gen R intercooler in a non-R IMG_20180301_182248941
Honda Civic 10th gen R intercooler in a non-R IMG_20180301_181909661
Honda Civic 10th gen R intercooler in a non-R IMG_20180301_181839915
So only .5"of extra height. Only adds ~11% frontal surface and volume. Considering I'll have to do some funky stuff with mounting, as it looks like the hard pipes provide most of the support and I can't use that. I'll be sending it back. Nothing ventured, nothing gained.
17siturb0
U.S North east
2017 civic si sedan, 2006 civic si coupe
vs Accord...
Thank you for taking the time to do this for us all, good information. At least you tried! Now we know for sure haha.
