Quick Fix for Scratches on Plastic Gear Shift Console
2016TouringSLC
Salt Lake City
2016 Honda Civic Touring
I had small scratches on my gear shift console almost from day one, and they only became more noticeable each time I dusted my Civic (even with a micro-fiber cloth).
I also build scale models, and a common trick is to put Future floor polish on canopies and other clear plastic surfaces because it fills and hides small scratches, it makes the plastic look more clear, and it protects the plastic. So I thought I would give it a shot on the plastic gear shift console, and I've been very happy with the results -- see attached photo but note that it looks even better in person.
Clean the console and then give it a blast of air as any dust caught in the polish will show. Use a wide modeling brush and try to avoid creating bubbles as you apply the polish. However, most bubbles will disappear and the polish will fill the micro-scratches and self-level. Again, avoid having any dust settle on the polish while it dries. Give it overnight and then it can be lightly buffed if you wish. If you don't like it, Future comes off easily with water and a little ammonia (Windex works great).
If you get scratches in the future, the polish can be reapplied.
Honda Civic 10th gen Quick Fix for Scratches on Plastic Gear Shift Console Honda Stick Shift
davidgostbo
Texas
Honda Civic Ex-t 2016
To protect your work, you should wrap it in clear plastic wrap!
Deezy
Daniel
Covington, Ga
2018 Civic LX Sedan 6MT (FC2)
Thanks for the tip! I'm going to try this where I have some scratches near my ignition, from my key.
saltycaramel
Glyn
Australia
Civic Hatch 18
Can you share which kind of polish did you use? Thinking to do the same using Meguiar PlastX/ScratchX & manually polish it with a microfibre cloth.
bluehatch17
bluehatch17
NJ
Cover it with carbon fiber vinyl or gloss black.
There are also abs plastic covers you can buy on eBay.
saltycaramel
Glyn
Australia
Civic Hatch 18
I've been trying to do the same but having difficulties finding one that would fit. As mine is a right hand drive, the wordings on the inner gear shift area is on the right instead of the left.
Would be great if anyone knows where to get those for a right hand drive model.
civicls
Upstate NY
2017 Honda Civic EX-T, 18' Odyssey Elite, 07' Sienna
VSS scratch and swirl remover works great for interior gloss scratches on all the cars I use.
