calvin13386
- Nov 21, 2018
- 44
- 3
- Singapore
- Honda Civic 1.5T
I am using a Ktuner V1.2 currently and flashed my ecu with the dual calibration 21psi stage 2 map. I encountered a few questions while exploring the KTuner software on my laptop.
1) Through the Tunerview app on my HU, I noticed that under WOT, the AFR does run rich to around 9.2. I did a check on my Ktuner settings under WOT as below snapshot, the AFR was supposed to limit at 11 but why does it not? Or does the value in the below table not represents the AFR?
2) I realized that KTuner base map are running slightly richer in terms of AFR How do I adjust the AFR to be slightly leaner. Is it at the above WOT page or under the below MAF scaling?
I am seeing the below table for AFM flow under MAF scaling, do I adjust under g/s which corresponds to the voltage to make the AFR leaner? If yes, do I adjust the g/s value to be smaller or larger? Any recommended values?
In the event if I do replace my intake with PRL CAI race MAF, do I adjust the MAF quick calibrations to "PRL Race MAF calibrations"?
3) I read through the forum and saw a user posting some recommendation for IAT ignition to reduce knock control. My current knock control does shoot up to 0.86 - 0.9 easily during cruising. Is the suggestion from that particular user a fairly safe number to follow and what does it affects?
4) What does ECT ignition do and should I or should I not adjust the values. are the "Corr" values meant the cam angles?
5) What is final boost target and what does it affect. Any recommendation on the values to set?
ps: I have send the queries to Ktuner before but was only told that my ECU number is just marked as initial support on their website so they did not give me any advice. As such, I have decided to reach out to other KTuner users for advice.
