Si PRL Motorsports Type-R Turbo Swapped 1.5T Civic Si
  1. 17siturb0
    17siturb0 Senior Member
    Dec 3, 2016
    1,319
    818
    Occupation:
    Health Care
    U.S North east
    2017 civic si sedan, 2006 civic si coupe
    323hp 348tq on pump gas, 360hp 397tq on E85 blend?
  2. kshawn
    kshawn Senior Member
    Apr 23, 2016
    1,667
    1,186
    Occupation:
    Desktop Support Specialist
    Maine
    2017 Civic SI
    :pickme:
  3. OP
    PRL Motorsports
    PRL Motorsports Premium Performance Products
    Jan 26, 2017
    1,156
    3,208
    Export, PA
    So here we have it... :headbang:
    326 hp & 305 tq on 93 octane pump gas and 342 hp & 319 tq on e30 blend fuel. We were very impressed with the pump gas power!
    Here is an e30 blend comparison of the stock turbo vs the Type-R turbo. Obviously with the larger turbo comes more turbo lag, about 1000 RPM worth. However, the engine now pulls to redline and peaks near 7000 RPM instead of 5200 RPM. The Type-R turbo softened the bottom-end torque spike significantly and made 20 ft/lbs less peak torque than the stock turbo. This powerband looks much safer on the stock motor/connecting rods. ;)
    @KTuner and @VitViper worked their magic on the VTC tables to make this setup work properly and pull to redline. We managed to hold ~29 PSI all the way to redline, unlike the Type-R 2.0T 's engine and turbo setup that starts dropping boost pressure up top. This just goes to show how well the small displacement 1.5L breathes with a larger turbo/turbine. The next obstacle to overcome is fueling, as we have now maxed out the factory fuel system.
    PNW_FC3, Scarlet, Xtelotatichl and 8 others thanked this.
  4. 360glitch
    360glitch Moderator
    3,710
    3,589
    2017 Civic Si Sedan
    :yes:
    Great results! I am curious though, with more fuel could you get more out of this particular setup?
    Scarlet thanked this.
  5. kshawn
    Apr 23, 2016
    1,667
    1,186
    Occupation:
    Maine
    2017 Civic SI
    29psi :respect: was this on factory internals? I'm assuming this was a SI as well.
  6. KTuner
    KTuner Senior Member
    Jul 10, 2017
    1,908
    2,485
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    Fantastic results!
  7. OP
    PRL Motorsports
    Jan 26, 2017
    1,156
    3,208
    Export, PA
    yes
    Scarlet and dallasjhawk thanked this.
  8. 2CAMS
    2CAMS Senior Member
    Aug 1, 2017
    84
    43
    FL, Miami
    CP
    Honda Civic SI 2017
    this cant be safe for this little 1.5 is it? also is this plug and play?
  9. LilToTo17
    LilToTo17 Senior Member
    Jul 14, 2017
    2,490
    1,126
    Occupation:
    Accountant
    Santa Rosa, CA
    Kevin
    This Type R turbo swap was just for testing only.
  10. davemarco
    davemarco Senior Member
    Jun 3, 2017
    2,068
    1,171
    New York
    2019 Civic Type R (CBP), 2001 Honda Prelude (Premium White Pearl)
    If the upcoming big turbo kit is based on this, then I would be interested in understanding whether internals would be required to be safe, and what the target cost would be.
    I've been holding fire on my purchases of the current PRL lineup in the hopes of maximizing my power/$ investment.
    kshawn thanked this.
  11. kshawn
    Apr 23, 2016
    1,667
    1,186
    Occupation:
    Maine
    2017 Civic SI
    Same
  12. OP
    PRL Motorsports
    Jan 26, 2017
    1,156
    3,208
    Export, PA
    Any kit we finalize will utilize our cobra cold air intake and front mount intercooler kit, along with the front pipe.
  13. kshawn
    Apr 23, 2016
    1,667
    1,186
    Occupation:
    Maine
    2017 Civic SI
    Any chance a water/meth kit would help with the fuel limitation? Untill possible upgraded fuel system options come out.
  14. Moltisanti
    Moltisanti Member
    Jan 3, 2018
    Pa
    2016 Ram
    Learn about turbocharging. Psi is irrelevant. It’s about power and torque.
  15. kshawn
    Apr 23, 2016
    1,667
    1,186
    Occupation:
    Maine
    2017 Civic SI
    I wouldn't say it's irrelevant.. but 29 at 7000rpm is easier on the engine then the same at 4-5k. Torque brakes things and with boost down low you make alot more tq. Move the boost up in the high range and you'll make more hp/power. That being said, to much boost and it dosnt matter where you're making it.
    Seeing 29psi on factory internals,on a 1.5 consumer Honda engine, is impressive in my mind. Even with it being moved to the high rpms, vs our rod bending stock turbo.
    bahndrvr thanked this.
