PRL Motorsports Project Snow White
  1. PRL Motorsports
    PRL Motorsports Premium Performance Products
    Jan 26, 2017
    1,227
    3,359
    Export, PA
    Project Snow White 10th Gen Si is now underway! We will be using this White Orchid Pearl coupe to test our PRL Motorsports products and push the limits of Honda's new DI 1.5T platform with the help from KTuner, LLC. First mod? Our Stage 1 Intake system while the dyno is getting moved this week. :thumbsup:
    Like our past record setting 9th Gen Civic shop car, we will provide baseline dyno numbers and data with our in-house Dynojet Research Inc. We will also be testing and backing up our Civic X product line with before/after gains on the dyno and at our local Keystone Raceway Park drag strip and Pitt Race road course.
    Our first impression? The 10th Gen Si is a very comfortable and well-performing car on the street; much more fun to drive than the 9th Gen Civic Si stock-for-stock. We are confident that this 1.5T will churn out some very fun/mpressive power with a reflash and simple bolt-ons. One major complain is how weak and spongy the factory clutch feels. The excessive rev-hang isn't too fun either, but this shouldn't be a problem for long ;).
    So far we have confirmed that the following products currently fit both Si and Non-Si Civics:
    • Downpipe/Front Pipe Combo
    • Downpipe
    • Front Pipe
    • Stage 1 Intake System
    • Stock Replacement Intake Hose
    • High Flow Drop-In Air Filter
    We are currently in the final stages of developing/testing our Cold Air Cobra Intake system for both the Si and Non-Si platform as well as our FMIC kit, stay tuned!
    An upgraded 6-puck clutch is on its way to us from Clutch Masters as of today, and we are working on narrowing down a proper wheel/tire choice to handle road course abuse. Slicks, skinnies and proper suspension are next on the list to be ordered. ;)
  2. elusiveaura
    elusiveaura Senior Member
    Aug 15, 2016
    1,019
    893
    Occupation:
    IT
    Tennessee
    18' Civic Type R CW , 18' Accord 1.5 Touring. 17 SI Sold
    Is this 6 puck clutch the same one that VIT is using? I need to know how much I have to shell out lol
    PRL Motorsports thanked this.
  3. JDM_DOHC_SiR
    JDM_DOHC_SiR Uncle Dave
    Apr 17, 2017
    925
    1,054
    Occupation:
    Government
    Chula Vista/ Eastlake
    2012 Acura TL Califonia Edition / 2018 Civic Si Coupe
    Can't wait to see how all of your parts work together on the Si... good stuff :thumbsup:
  4. OP
    PRL Motorsports
    Jan 26, 2017
    1,227
    3,359
    Export, PA
    To our knowledge, similar but not the same (just due to our preference). These will be available on our site later today!
    elusiveaura thanked this.
  5. elusiveaura
    Aug 15, 2016
    1,019
    893
    Occupation:
    IT
    Tennessee
    Sweet. Also, the down pipe will work on an SI and no tune is required? I will get a tune eventually but does it work fine without it?
  6. OP
    PRL Motorsports
    Jan 26, 2017
    1,227
    3,359
    Export, PA
    You will need KTuner to disable o2/cat related CELs.
    We got around to dynoing our Project Snow White Si earlier this morning and put together some graphs/data for the forum. We began testing this morning with the stock intake when the temperature was in the upper 60's (Farenheit) which is rather mild for this time of year in PA. Immediately we noticed how sensitive and vulnerable these cars are to heatsoak.
    Above are three consecutive dyno pulls with only a few short minutes between each, notice how drastically power is lost as heat accumulates. The car made a best of 187 hp and 215 ft/lbs tq during the first pull. Typically we like to start dyno pulls around 180 degrees Farenheit for coolant temps and 100 degrees for air temps. We saw a max of 225 degrees for coolant temps and around 115 degrees for air temps towards the end of run 3. Notice how power drops at around 4400 RPM for runs 2 and 3? The knock control value increases and the ECU pulls timing. :doh:
    Here is a comparison of heaksoaked 3rd gear pulls and heatsoaked 4th gear pulls. Notice a trend? :hmm:
    The car liked 3rd gear pulls much better, it kept temps almost tolerable. We saw 196 whp and 205 ft/lbs tq here.
    While we were at it we decided to do some before/after runs testing our Stage 1 intake system. We never really anticipated this kit to be a big power maker, more or less a simple bolt-on mod for customers looking to improve aesthics and air flow. With that being said, we were rather impressed with what we came to find during testing.
    We recorded four dyno pulls with the Stage 1 Intake system. During the four 3rd gear pulls we noticed that the knock control value continued to drop, which shows an increase in efficiency, whereas the knock control value with the factory intake system is rather sporatic. As this knock control value decreases the ECU continues to add timing and allow the car to make more power. Our stock 10th Gen Civic Si made a best of 200 whp and 210 ft/lbs tq on our DynoJet.
    Here is a 3rd gear comparison of the stock intake system and our Stage 1 intake system. We chose to compare these runs because of how identical knock control values, coolant temps and air temps were (within +/-1%).
    Here is a 4th gear comparison of the stock intake system and our Stage 1 intake system. Again, these two graphs show identical parameters. These numbers and gains held consistent into the late morning when temperatures rose about 7 degrees Fahrenheit into the mid 70's
    With that being said, we managed to see mesaurable gains with our Stage 1 intake system in comparison to stock. Customers can expect a 4-9 whp gain without a tune by simply bolting in our high flow drop-in filter and silicone intake hose. We expect to see MUCH larger gains with our cold air intake system. :thumbsup:
    Keeping coolant and air temps cool is crucial to keeping your engine happy. We are going to experiment with a thicker, more efficient radiator to imrove cooling, as well as begin testing our FMIC and CAI to see how that effects air temps!
    das borgen, bahndrvr, Design and 5 others thanked this.
  7. elusiveaura
    Aug 15, 2016
    1,019
    893
    Occupation:
    IT
    Tennessee
    That's a lot of good data right there. Thank you. I was wondering about your stage 1 kit but I think I'll wait on that CAI system you're making. I'm sure that one will require a tune, correct? Have an ETA or price thought on what that CAI will be? Thanks again for the work you guys do!
  8. JDM_DOHC_SiR
    Apr 17, 2017
    925
    1,054
    Occupation:
    Government
    @PRL Motorsports thank you for documenting this... I will be sure to follow what your doing with your up and coming parts...:hmm: Very interested and amazed at quality of the products you offer :thumbsup:
    :D
    Now if you could just get a group buy started for the Cobra intake that would be great mmmmmmmmmmmkay:rofl:
  9. OP
    PRL Motorsports
    Jan 26, 2017
    1,227
    3,359
    Export, PA
    So far we are finding that our "Street" CAI will also be bolt-on that does not require a tune due to the fact we 3D scanned and machined an identical billet aluminum MAF housing to duplicate factory like driveability and response.
    No problem at all, it's what we're here for! :) We're always open to exposing our findings, in an effort to push this 1.5T platform further for everyone in the 10th Gen Community.
    We plan to have these for sale in within the next two weeks or so!
  10. elusiveaura
    Aug 15, 2016
    1,019
    893
    Occupation:
    IT
    Tennessee
    Sweeeeeet. Whats the expected gains on the CAI? And what is FMIC? :)
  11. dallasjhawk
    dallasjhawk Senior Member
    Oct 3, 2016
    3,931
    3,833
    Arlington, TX
    2016 Civic EX-T, 2004 Acura TSX
    Front Mount Intercooler
  12. Shankmeyster
    Shankmeyster Senior Member
    Mar 15, 2017
    2,791
    1,289
    AZ
    2017 Civic Sport Hatch 6MT
    I doubt people will want a 6 puck for daily driving.
  13. NeoDragons
    NeoDragons Senior Member
    Jun 19, 2016
    1,246
    1,023
    Occupation:
    Parts Stock Controller
    Guam
    2016 Honda Civic Sedan EXT
    i rememeber when i drove my friends 99 civic with a six puck clutch around. that sucked in traffic, lol
    ne0guri thanked this.
  14. OP
    PRL Motorsports
    Jan 26, 2017
    1,227
    3,359
    Export, PA
    We've always used and recommended 6-puck clutches for most FWD/RWD race/heavy street applications making decent power/torque numbers. This car will be seeing heavy abuse from launching and high-rpm full-throttle-shifts, which is a big no-no for full-face organic clutches. Full-face organic discs have a tendency to slip and wear much quicker than puck-style clutches in from past experience; we've seen many organic discs birds-nest, or ball-up. If you plan on launching the car and racing on the track or in Mexico, we strongly suggest looking into a puck-style clutch setup.
    There's always a trade-off, do you want a clutch that holds the power and abuse, or do you want a "comfortable" clutch? Keep in mind that the pressure plate and sprung vs unsprung disc plays a big part of the comfort factor. A sprung puck-style clutch with a moderate strength pressure plate can be street driven without much hassle (in our opinion). Rigid (unspring) discs with heavier pressure plates will be harder to drive, but this can be avoided for the average bolt-on guy. 95% of our 8th and 9th Gen customers daily drive or street drive their 6-puck clutch with our turbo kits and have no complaints.
    DavidGenXCivic and elusiveaura thanked this.
  15. UberCivic
    UberCivic Senior Member
    Jul 20, 2016
    448
    340
    Michigan
    2016 Modern Steel Civic EX-L 2006 Highlander Hybrid 2002 Honda Insight 2000 Audi A6 2.7t
    OT, but have you ever eaten at Vitale's? Guam is a small place so I have to ask.
