PRL Motorsports P600 Honda Civic Type-R FK8 Drop-In Turbocharger Upgrade Development
  1. PRL Motorsports
    PRL Motorsports Premium Performance Products
    Jan 26, 2017
    1,234
    3,366
    Export, PA
    As many of you have seen, we began testing a potential drop-in turbocharger upgrade for the FK8 Honda Civic Type-R in July of 2019. We managed to produce 460+ horsepower and 430+ ft/lbs torque on stock engine and produced close to 500 horsepower with third party testing with our first prototype turbocharger. Though we were satisfied with the results of this particular turbocharger, we still felt that we could design and produce an even better performing upgrade for the community. Here is what we’ve come up with over the past few months:
    The PRL Motorsports P600 Drop-In Turbocharger Upgrade for the 2.0L Turbo FK8 Civic Type-R platform (which can also be installed on the 2.0L Turbo Honda Accord and Acura RDX) will utilize a billet 304 stainless steel, dual ceramic ball bearing CHRA for reduced weight and improved durability. This turbocharger retains factory oil and coolant lines, as well as the factory bypass valve and wastegate actuator. Our new CHRA is also designed to increase cooling capacity with its larger water jacket.
    For reference, here is a comparison between the factory Mitsubishi TD04-T/C, our prototype turbocharger, and our P600 turbocharger:
    Our High Efficiency compressor wheel is significantly taller than most billet compressor wheel upgrades and features the latest technology in aerodynamics (tapered tip exducer, cutback design on blade top edge) for optimal spool and power. This High Efficiency Turbine Wheel also features the latest technology in aerodynamics for optimal spool and power.
    The P600 Drop-In Turbocharger Upgrade will be capable of delivering up to 600 wheel horsepower and we also expect similar spool as our prototype unit despite being larger, which was near factory to begin with.
    Stay tuned as we continue to post updates as they come, and test results once we have a production sample. Pricing is to be determined, but current ETA is the summer of 2020!
    http://prlarmy.com/Blog/prl-motorsp...fk8-drop-in-turbocharger-upgrade-development/
    BoostedDreams, flixman, akadic and 8 others thanked this.
  2. Tim818
    Tim818 King Of The ‘Ring
    Dec 19, 2015
    1,457
    1,285
    Texas
    2006 Civic EX, 2018 CTR
    Very nice @PRL Motorsports, you guys made my decision not to go with a turbo kit lol
    PRL Motorsports thanked this.
  3. frtorres87
    frtorres87 Senior Member
    Dec 4, 2018
    510
    441
    New Jersey
    Frank
    2017 Honda Civic Type R
    Sign me up
  4. flixman
    flixman Senior Member
    Jun 3, 2017
    148
    37
    Los Angeles California, USA
    2017 Honda Civic Type R - Black
    so your titanium intake and down pipe should bolt up to it. no need to buy anything else other than your turbo. i owned every single item you made for the FK8
  5. Japsw20
    Japsw20 Member
    Oct 28, 2019
    Miami
    Ron
    19 CTR
    On what fuel system? Any news on an affordable fuel system besides the Hondata?
  6. Naruske
    Naruske Senior Member
    Mar 10, 2017
    300
    180
    NJ
    2019 CTR
    Someone asked on their IG post if the stock fuel system was enough and they responded with yes so we should be gucci.
    Also Hondata mentioned a while back that they were pushing beyond 450HP(dont recall the exact number) safely for a year on stock internals so this makes me beyond excited!!! Honestly with 450HP and 430TQ, i am more than happy
    frtorres87 and PRL Motorsports thanked this.
  7. OP
    PRL Motorsports
    Jan 26, 2017
    1,234
    3,366
    Export, PA
    Yes, this turbo will be compatible with all of our current products!
    flixman and LilToTo17 thanked this.
  8. frtorres87
    Dec 4, 2018
    510
    441
    New Jersey
    Frank
    I feel the exact same way. If I can get anywhere near 450whp on 93 octane with stock internals I’m down! I won’t need much more than that.
    PRL Motorsports, Naruske and MstrSHAKE thanked this.
  9. TypeSiR
    TypeSiR Senior Member
    May 15, 2017
    1,324
    894
    Occupation:
    Car Driver
    1.5T Civic, CTR, MX-5, Fit
    450/430 needs upgraded clutch? No?
  10. Japsw20
    Japsw20 Member
    Oct 28, 2019
    Miami
    Ron
    19 CTR
    Hondata is too proud of their fuel system at what they’re asking, we don’t need the injectors at 400ish range just a fuel pump.
  11. Kcj1990
    Kcj1990 Member
    Jul 18, 2019
    NJ
    Kenneth
    Civic Type R
    Very likely!!
  12. roflitzjinno
    roflitzjinno Member
    Sep 26, 2019
    Chicago, IL
    Jinno
    Honda S2000
    Excited to see this come out.
  13. AdamD19DFK8
    AdamD19DFK8 Senior Member
    Jul 11, 2019
    257
    103
    Maryland
    Adam
    2019 FK8 Type R, 2007 Civic Si sedan
    #13 AdamD19DFK8, Jan 16, 2020
    Yeah I was banking on prl having a good turbo option, their proto type was a drop in upgrade so I new the updated one would be as well. I'd hate to have spent all of that money on parts literally starting from intake/inlet all the way through to the end of the exhaust, and then get a kit which usually has a custom intake/inlet, downpipe, charge pipes. I already have the prl versions of all of those lol.
    I'm curious what to see what this can get on the stock fuel system at a safe afr. I'll need a new clutch regardless, and at least rods and pistons if I want to go way past 400ft/lbs
    Also, @PRL Motorsports is there a reason why the hot side isn't pictured?
    PRL Motorsports, Tim818 and frtorres87 thanked this.
  14. flixman
    Jun 3, 2017
    148
    37
    Is this turbo moving the torque band across so not to put strain on the engine like the stock turbo does?
  15. Tim818
    Dec 19, 2015
    1,457
    1,285
    Texas
    Yeah this definitely changes a lot of things, I have the HVI already and have the inlet pipe shipping to me in February. I may have to buy another PRL catless downpipe again along with their intercooler and charge pipes. As for building the engine, I have all the parts that you can buy from 4piston, just waiting to see what other fuel system upgrades are coming out instead of Hondata.
