CivicLX2016
Tried to look through...what exactly does this add to car?
From what's been announced so far(a lot of heresay on my part, read it everywhere but never from hondata themselves yet), no they do not have plans to do so.Will it be a direct bolt up to the Invidia N1 exhaust?? Does Hondata have a plan to remove the CEL light for the non cat version??
Larger diameter exhaust tubing, less restriction, etc, meaning more horsepower and torque.Tried to look through...what exactly does this add to car?
Yes, this will bolt right up to an aftermarket exhaust. No, Hondata does not plan on doing so.Will it be a direct bolt up to the Invidia N1 exhaust?? Does Hondata have a plan to remove the CEL light for the non cat version??
Correct, from what was said at the Seminar, they are looking to gain a CARB approval and offer flashed maps that aid in power gains and fuel economy.From what's been announced so far(a lot of heresay on my part, read it everywhere but never from hondata themselves yet), no they do not have plans to do so.
http://prlmotorsports.com/2016hondacivicsicr-vturbochargerupgradekit.aspx#.WJp1Zo5QDVo This Kit comes with the turbocharger and gaskets for $749.99, brand new OEM Honda pieces. Perfect for customers who want a bolt-on turbo upgrade, but also a great solution for guys with smoked stock turbos. This turbo is actually cheaper than a stock replacement.Link to the turbo's?
This is not your "possibly planned" turbo upgrade is it?http://prlmotorsports.com/2016hondacivicsicr-vturbochargerupgradekit.aspx#.WJp1Zo5QDVo This Kit comes with the turbocharger and gaskets for $749.99, brand new OEM Honda pieces. Perfect for customers who want a bolt-on turbo upgrade, but also a great solution for guys with smoked stock turbos. This turbo is actually cheaper than a stock replacement.
Yes, look for some intake information within the next couple of weeks.Any intakes coming?
We may or may not be exploring avenues.This is not your "possibly planned" turbo upgrade is it?
Do you mean gains without custom tuning? Because aren't those +40/+50 gains WITH hondatas included +6psi flash?So, we finally got around to testing the catted version on our CVT shop car. The results were rather impressive!
Listed below is a dyno graph depicting a bone stock 1.5T CVT dyno without a flash (blue line), the same car with our catted downpipe and front pipe (red line), and the same car with our catted downpipe, front pipe and Hondata's +6 PSI reflash (green line). Peak torque came in about 400 RPM sooner than with the factory cat and the car picked up massive amounts of bottom end power, over 40 whp and 50 ft/lbs of tq to be exact, at about 4300 RPM. Peak gains were 10 whp and 14 ft/lbs tq while these gains held true throughout the entire power-band, with over 20 ft/lbs tq gains up top.
We initially expected similar gains from the catless version, but these catted results blew us out of the water. We can't wait to see what sort of gains we will see from the catless version once Vit tests both versions on his 6MT car.
Catted Downpipe + Front Pipe Gains WITHOUT Tuning:
- 400 RPM increase in peak torque
- 40+ hp and 50+ ft/lbs tq down low
- 10 hp and 14 ft/lbs tq at peak
- 10 hp and 14-20+ ft/lbs tq throughout mid-range/top
- No CEL
