PRL Motorsports Bolt-On Big Turbo Upgrade Kit
  1. farqt
    farqt Senior Member
    Sep 4, 2018
    85
    36
    NE
    18 si
    the gen 1 gtx2860r disco potato just has a much higher choke point than the gt2860 (for the most part, it depends on the housing, chra bearing build, etc, but if you look at the garrett compressor maps that is what you'll see). the gen 2 gtx2860r is where you will big gains over a vanilla disco at the same same exhaust pressure.
    i would be very surprised if they aren't testing on larger injectors and simulating factory fueling for package testing experiments and running ethanol blends on the larger injectors for peak power measurements. this is the same approach i am taking with my project car (ie, not the honda) and that most of the turbo builders i know use in testing (with a spare block for every car they're testing on)
  2. AREA
    AREA HTX X GENZ @HTXXGENZ
    Sep 5, 2018
    342
    293
    Occupation:
    Structural Engineer
    Houston, TX
    95 hatch Drag car, K20Z3 00 Integra, 07 Civic SI sedan and 18 Civic SI coupe
    Didn't Eman just make 465 dynapak with this turbo kit and meth injection on Motec?
    PRL Motorsports thanked this.
  3. 360glitch
    360glitch Moderator
    3,522
    3,400
    2017 Civic Si Sedan
    Yep!
  4. AREA
    Sep 5, 2018
    342
    293
    Occupation:
    Structural Engineer
    Houston, TX
    Waiting to see what turbo Eman chose!
  5. davemarco
    davemarco Senior Member
    Jun 3, 2017
    1,506
    846
    New York
    2019 Civic Type R (CBP), 2001 Honda Prelude (Premium White Pearl)
    GTX2867 Gen 2. Looking at the power curve that he posted, it honestly resembles a turbo 8th gen, but without the 8K RPM red line. Very low power on the low end (<100 hp by 3000 RPM), climbing to decent power in the mid-range, and crazy power on the high end. He also raised his redline to around 7K RPM.
    That said, I have to wonder how fun it would be to drive in non-racing conditions, considering that the low end power has been completely gutted and the stock engine can't rev to the moon anymore.
  6. 360glitch
    360glitch Moderator
    3,522
    3,400
    2017 Civic Si Sedan
    I think that turbo is going to be more well suited for track use. I wonder which exhaust housing he is using. Probably the larger one?
  7. farqt
    farqt Senior Member
    Sep 4, 2018
    85
    36
    NE
    18 si
    i think the 2867 is too big for this motor. if it had a head and internals that could spin up to 8k without destroying itself, you could take advantage of the upper end of the compressor map, but without the exhaust pressure to take advantage of the upper end of the curve, you're effectively tossing in a 2860 at higher cost and higher lag.
    otoh if you have a bored out built motor and ported head, you could push enough power with the 2867 to retain drivability and twist the chassis in half at high rpm...
    PRL Motorsports and kshawn thanked this.
  8. kshawn
    kshawn Senior Member
    Apr 23, 2016
    1,360
    847
    Occupation:
    Desktop Support Specialist
    Maine
    2017 Civic SI
    Well the built motors are right on the horizon. So we'll find out soon enough
  9. kshawn
    Apr 23, 2016
    1,360
    847
    Occupation:
    Maine
    2017 Civic SI
    @PRL Motorsports I think I saw somewhere you guys are switching to motec for a ECU. Are you running into limitations with the stock ECU?
  10. farqt
    farqt Senior Member
    Sep 4, 2018
    85
    36
    NE
    18 si
    Torque tables and limited fueling probably. The honda ecu interpolates everything.
    Also VE changes significantly with any changes to the internals, and standalones seem to be the way to go when VE changes on most modern cars that do extensive sensor reconstruction using baked in curves
  11. fiend busa
    fiend busa Senior Member
    Apr 22, 2017
    792
    293
    2018 Civic Type R
    Has there been any updates to this project? Haven't seen anything for a while :eek:
  12. davemarco
    Jun 3, 2017
    1,506
    846
    New York
    Got this update from customer service a couple weeks ago:
    "We are currently working on packaging up clamps, silicone, hardware bags and whatnot as we speak. All components aside from coolant lines and downpipe castings are here in our location getting ready for packaging. With that being said, coolant lines and castings are scheduled to arrive towards the end of the month, which means we can begin welding up downpipes and wrapping up kits once received.
    Early November is looking very promising for shipment ETA."
  13. OP
    PRL Motorsports
    PRL Motorsports Senior Member
    Jan 26, 2017
    894
    2,466
    Export, PA
    We apologize for the slow delays on the kit, it's been hard to find time to snag pics and set things up for you guys. Please don't worry though, we've been busy moving forward with packing up components and kits! :) As of now all components are here and in the final stages of packaging aside from downpipes. Upper and lower downpipe castings are scheduled to arrive shortly and will then need machined, fabricated and welded up to ship kits. Here's a sneak peak of what customers can expect to receive (minus downpipe).
    A few key points to touch on for the community:
    • 4-ply silicone couplers rated for high temperatures with receiving grooves for seamless connections and ease of installation
    • Zinc coated coolant lines and oil feed fittings for OE finish
    • TRUE Ceramic coated intake crossover pipe assembly
    • 304 stainless heat shield
    • Stainless multi-layer gaskets
    • Stainless and Zinc coated hardware
    • TurboSmart Kompact Recirc BOV
    bahndrvr, HammerSi, AREA and 1 other person thanked this.
  14. OP
    PRL Motorsports
    Jan 26, 2017
    894
    2,466
    Export, PA
    We have tested quite a few different ethanol blends, mapping, the GT2860RS, GTX2867R GEN2 and now the GTX2860R GEN2. The engine is pretty much at max potential until we can get past the MAP sensor limitation and fueling limitations.
    Eman has the GTX2867R GEN2 and small .64 A/R housing, the 67 is just that lazy on this small 1.5L motor. We feel that the 2860's are the optimal solution for street guys, but for Eman that is going to pushing the limit racing, the 67 makes sense. We feel that these cars truly need a camshaft upgrade to make the most of anything larger than a 2860.
    We do have a CSS machined block and JE pistons here awaiting our rods to come back from Crower to assemble for backup. The rods are going to be the first weak point. We also have Crower valve springs, retainers and locks to install for safety, but the factory cams are already a limiting factor. We really need a camshaft solution to make the most out of upper RPMs.
    We do have a MoTeC setup here for when we are ready to push things to their maximum potential, but we would like to retain the factory ECU and KTuner as long as possible to help keep developing and pushing this platform for the community. We understand that most customers will never choose to go MoTeC, so it doesn't make sense for us to abandon ship on a project that still has potential and appeals to the community.
    NoKz, bahndrvr, HammerSi and 4 others thanked this.
  15. farqt
    farqt Senior Member
    Sep 4, 2018
    85
    36
    NE
    18 si
    Thanks for the update!
    Long term, it would be nice to know whether you can build the 1.5 longblock for big power or whether we should be looking for k20t motors out of crashed accords..
