PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System
FK8_K20c1
Jonathan
Indiana
FK8 Type R
Thought I would share mine.
No errors
No issues with fitment
No problems getting it on tight
No gaps
All goodness
I have the same gap you have on the turbo inlet. No biggie.
FK8_K20c1
Jonathan
Indiana
FK8 Type R
Drove today for 11/2 hrs and maf temps behavior on stop and go traffic plus highway driving beats the stock airbox with high flow filter and prl stage 1 and the mishimoto intake out of the water. Temperatures went as low as 6 degrees above ambient at one moment. Mostly stayed about 8-9 degrees. Even on traffic when it will get 130deg hot as soon as you start driving it goes down quick. Nice work PRL.
jinderC
Great info!
elusiveaura
Tennessee
2020 CW CTR - 2020 Acura RDX A-Spec
Mine was like that at first but I found if I put my hand underneath that side and twisted and pulled towards the pipe I could get it a lot closer. Just a suggestion.
Put on some neochrome looking bolts today!
This is the closest I could do for the gap.
TypeSiR
On a Twisty Road
1.5T Civic, Fit, MX-5, CTR
Just finished installing mine and went out for a night drive. The induction noise and woosh sound is LOUDDDD! A lot louder than the AFE that I had for a week and decided to take it off.
The installation took me 2 hours, mainly because it was hard to get the silicone hose to fit right. The evap flange rubs against the vac pipe, and I couldn't get it not to rub. There's not much wiggle room because silicone hose is thick and thus not as flexible. Also, the silicone hose doesn't go all the way to the turbo inlet pipe, leaving a 2mm gap. The airbox is also rubbing against the bracket that holds the MAF sensor wire to the fuse box. This is not a big deal though but just something I want to point out. Performance wise, I don't notice any increase, but I expected it.
Overall, I'm keeping this intake. Let me know if you guys are having the same issue with the silicone hose.
I’m thinking of cutting the hose (green) 2mm to eliminate the rub (red). Currently, the flange is rubbing the paint off of the vac pipe. Most people won’t notice the rub unless they look for it in the area.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System 77E7EC38-F6EF-4D55-90F1-6C3EBA8DF6E7
jinderC
You can push and bend that metal hose back and away from the Evap plastic housing just enough to make it stop touching.
It’s what I did, no problems.
jinderC
I also find that my Thermal RD exhaust now sounds even more audible after installing the PRL intake..... in a good way.
I hear more cracks and pops.... also it tends to be slightly louder and more raw.
It’s awesome!
VinRRR
Empire State
R16017
I was thinking of that too, but I don’t have the tool to make sure it’s a straight cut. The paint on that pipe is so easy to come off, I was like wth lol. A lot of people rotate the flange to a horizontal position, and that helps with the rubbing. However, by doing that, the hose on the right will point upward and may potentially rub against the hood. A few solutions I can think of: 1. Make the flange adapter thinner 2. Make the hose bend toward the front more (like stock) 3. Like you said, make that evap hose shorter.
Imagine you bend a little too much and break a hose! Yikes!
It’s awesome!
I notice my HKS is a little louder and has has more pop while shifting as well. Love it!
DuneShoot
AZ
'19 CTR, '16 Tacoma
Got mine installed today too. Over all it's pretty nice.
Would like the connecting pipe between the air box and inlet pipe 1/2" longer. 1/4" on the inlet pipe would be more assuring and 1/4" on the airbox connection too.
Minor gripe I agree but it seems most who have installed these has the same gap issues.
