PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
Pulled from the PRL Army Blog
Install Time: 1 Hour
Disclaimer:
  • Install was performed on a modified application. Some hardware shown may be different than the hardware used on the stock
  • vehicle.
  • Allow vehicle to cool completely prior to attempting installation.
  • PRL Motorsports is not responsible for any vehicle damage or personal injury due to installation errors, misuse, or removal of PRL Motorsports products.
  • PRL Motorsports suggests trained professional installation all PRL Motorsports products
Table of Contents:
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7304_zpsxbfqzm3h
  • (1) Air Box
  • (1) Air Box Lid
  • (10) M5 x 0.80 x 10mm Button Head Cap Screw for Air Box Lid
  • (1) Billet Aluminum MAF Housing
  • (1) Billet Aluminum Velocity Stack
  • (1) Oiled Cone Filter
  • (1) Silicone Inlet Hose
  • (1) #52 Stainless Steel Worm Clamp
  • (1) #44 Stainless Steel Worm Clamp
  • (1) #20 Stainless Steel Worm Clamp
  • (1) #8 Stainless Steel Worm Clamp
  • (1) Stainless Steel Air Box Bracket
  • (1) Billet Aluminum Evap Bung
  • (1) 12" Convoluted Tubing
  • (4) M6 x 1.00 x 16mm Socket Head Cap Screw for MAF Housing to Velocity Stack
  • (2) M4 x 0.70 x 8mm Socket Head Cap Screw for MAF Sensor
Tools Needed:
  • Ratchet
  • Extension (12" Length)
  • 10mm Socket
  • Flathead Screwdriver
  • Phillips Screwdriver
  • 3mm Hex Allen Key
  • 5mm Hex Allen Key
  • Electrical Tape
Air Box Preparation:
Loosely install velocity stack into cone filter
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7311_zpsq8ilkcac
Place the loosely attached air filter and velocity stack assembly into the air box. Rotate the band clamp so that the screw is easily accessible in the air box.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7315_zps98g0ot3t
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7316_zpsimyorw0r
Attach the MAF housing to the velocity stack by aligning the holes through the air box with the (4) socket head cap screw bolts. Torque bolts to 11.2 in/lbs or until snug.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7317_zpsmvaic3zy
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7322_zpsoz5xzuia
Loosely attach the air box lid with 8 of the 10 button head cap screw bolts, carefully working your way from one side of the box to the other.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7324_zpsftlw84a7
Once all bolts are placed through the air box lid's holes, tighten to 24 in/lb or until very snug. (Blue Loctite is not a bad idea either)
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7326_zpsqokhpfp2
Loosely attach the air box bracket with the flat tab facing down using the remaining 2 of the 10 button head cap screw bolts. Leave these bolts loose so that the bracket can slide from side to side for optimal fitment.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7327_zps2h4n6u2r
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7328_zpsm6c55j8
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Removal of Factory Intake System:
Disconnect the the battery by removing the positive terminal and carefully placing this to the side.
Remove the factory intake hose by removing the 2 hose clamps at the very ends of the intake hose assembly using a flathead screwdriver. Only the clamp that attaches the hose to the turbocharger inlet pipe and the clamp that attaches the corrugated inlet hose to the air box need to be removed. Remove the vacuum line attached with the hose clamp and the 2 10mm head bolts that attach the Evap purge valve to the plastic housing.
Disconnect the MAF sensor by pressing on the clip and pulling out.
Remove the MAF sensor wiring harness from the retaining clips and casing by using a flathead screwdriver to release the detents. Pull this harness and its exposed wires to the side.
Remove the MAF Sensor from the factory MAF housing by using a Phillips Head Screwdriver.
Remove the two 10mm head bolts at the front of the air box.
Remove the 10mm head bolt at the back of the air box that goes through the rubber mount.
Remove the 10mm head bolt located on the right side of the air box between the ECU using an extension.
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Remove the air duct seal by releasing the tabs. Usually these can be removed by pulling to the (left) side to detent the tabs. A flathead screwdriver may need to be used if this becomes problematic.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7336_zps04j0ffh1
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7337_zps66xin2fl
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7359_zpspxocyr3x
Lift up on the rubber tab on the air box seal using a flathead screwdriver.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7338_zpsbnidi37y
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7339_zpscf00qcs
Lift on the air box to remove the air box assembly from the engine bay. Air box may need to be wiggled release from the rubber locator.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7344_zpsbsdusvd
Remove the rubber mount on the back of the factory air box by pressing down to slide out the metal sleeve in the middle. The rubber grommet will then be able to be pressed out.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7349_zpsvnlrjmhm
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7353_zpszzikasp1
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Reinstall this rubber mount and sleeve the same as it was removed.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7355_zps8brjyzva
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7356_zps7cxtlzm
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7357_zpsnj0gykpw
Remove the rubber locator grommet on the bottom of the factory air box. Use a flathead screwdriver if needed.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7375_zps47xhspfh
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7376_zpswwcqtds7
Reinstall the rubber locator grommet on the bottom of the High Volume Air Box the same as it was removed. Lubricant can be used if necessary.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7377_zps5cypnwx
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7378_zpsnni9whq2
Installing the High Volume Intake System:
Install the MAF sensor into the billet MAF housing using the 2 M4 socket head cap screws. Torque bolts to 5.9 in/lbs or until snug.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7347_zpszg7i5c9d
Take the supplied convoluted tubing and place it over the now exposed wires on the MAF sensor wiring harness. Electrical tape this to make a weather-tight seal.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7360_zpsuqqqllot
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7361_zpsxxmrywy4
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Route the MAF sensor wiring harness under towards the center of the engine bay as far as possible (without pulling) and place the High Volume Air Box into the engine bay. Make sure to press down on the lower locating grommet to pop into place.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7362_zpspa680jys
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7380_zpszsnfkcvw
Plug the MAF sensor into the harness.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7364_zpszprepr5a
Place the #44 hose clamp onto the turbocharger inlet pipe side first before installing the silicone inlet hose.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7373_zpsbuwjdjhw
With the air box still loosely installed, loosely attach the silicone inlet hose to the billet MAF housing with the #52 hose clamp loosely installed onto the hose.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7374_zpsrhjjear8
Place the small vacuum nipple into the silicone inlet hose.
Slowly work the turbocharger inlet side of the silicone hose onto the inlet pipe by pulling back on the silicone.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7381_zpsyxbrt61z
Place the Evap purge valve to the supplied billet bung.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7382_zpsiqj6icwd
Tighten down the flanges using the factory 10mm head bolts.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7383_zpsc7ohmjsc
Rotate the Evap flange like so to avoid rubbing. Tighten the #8 and #20 clamps until snug.
*Trimming of the evap portion of the silicone (And/or vacuum hose) may be required up to 1/2” for evap assembly to clear hood.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7385_zpsmxkxme5q
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7387_zpsajghzrn
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Align the rubber mount at the rear of the air box with the hole on the chassis. Tighten down the 10mm head bolt.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7367_zpslxi79mj0
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7369_zps02txej4x
Tighten the 2 10mm head bolts at the front of the air box.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7371_zpswtfwejze
Tighten down the 2 button head cap screws at on the air box bracket.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7372_zpsag4wdby
Attach the factory air duct seal to the High Volume Air Box by pressing the clips in.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7388_zpsmzxkuxk2
Double check all connections to ensure that everything is tight. Address any necessary issues. Once everything is finished, reconnect the battery.
Honda Civic 10th gen PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System Install Guide DSCN7389_zps2s74x28h
DuneShoot
AZ
'19 CTR, '16 Tacoma
Nice write up, thanks!
Not looking forward to removing most of that to clean the filter but that's the way it is :)
davemarco
How close is the turbocharger inlet pipe to release? I've already ordered the High Volume Intake System, but after seeing how involved the install is, I'd rather not have to disassemble things again to install the inlet pipe.
jasonjm
Jason
Pennsylvania
Type-R
Not quite.....
Something you do once every 2 years if that....hardly anything to cry over
I wouldn’t throw that number out there because It all depends on where you live and how you drive. For my drive cycle I’ll be cleaning it every 6-8 months. This ain’t my first rodeo.
