idragmazda
Man, you 1.5 guys get all the cool ish!
Don’t be one of those CTR owners before you’re even a CTR owner.As a current '17 SI owner and soon to be '19 Type R owner, thank you to all of the early adopting SI owners that will be living in uncertain times while the kinks get worked out. The sacrifice of your time and money will ensure that by the time the kit for the R gets made, there will be a clear upgrade path established.
I can't wait to see how high we can push the R's top end on the stock turbo, once we get extra fueling!
Detected a hint of future Elitism in there did you. Lol.Don’t be one of those CTR owners before you’re even a CTR owner.
https://www.merriam-webster.com/dictionary/jokeDon’t be one of those CTR owners before you’re even a CTR owner.
Best reply on this thread by far lol
I get the feeling that @KTuner might provide such type of fuel controllerWould not be a firmware change for a tuner device; would need to be a "stand alone" controller. More than likely using R4 Engine Software.
The wiring would need to be tapped into stock coil packs, MAF, and ECU + it's own injector set. Fuel link to the HPFP as well. Now, it needs to be flashed; preferably using a LOAD based target for reliability (thus the connection to the MAF).
I believe I missed a great many finite details, but that is about the bread & butter.
That kind of system would allow FULL E85 fueling; but, the Low End pump would need to be upgraded as the demand would be higher than the supply. This also depends on the size of injectors being used as well.
All in all, would be a nice to system just to release the strain on the fueling system and keep the Cylinders cooler + the valves cleaner than sparkling teath.
doubt it lol your on your own for custom setup.I get the feeling that @KTuner might provide such type of fuel controller
And we are familiar with “plug and play” harnesseses that come with ethanol kits for example
Would have to be a "lucrative" investment by someone. Would also apply to a narrower clientele.I get the feeling that @KTuner might provide such type of fuel controller
I wouldn’t doubt anything. Its a big 10thgen community with a lot of aftermarket support. Some company is going to want to capatilize on this new moddoubt it lol your on your own for custom setup.
I wouldn’t doubt it but it’s going to cost a pretty pennyI wouldn’t doubt anything. Its a big 10thgen community with a lot of aftermarket support. Some company is going to want to capatilize on this new mod
You can use a PI system for more than just additional power. It can be used for cooler combustion, keeping the valves clean, and w/o spikes in the entire ignition cycle (consistantly).I wonder at what point it will cease to be worth the upgrade. Like, let's say that you have a fully built engine pushing 500 whp and 600 ft lbs of torque. Would any rubber even be capable of letting a FWD car put that down? I've read about 350+ whp CTR's with 380+ ft lbs of torque that can spin in 4th gear if the driver were to step down. At what point does it cease to be useful?
I understand that users are responsible for sourcing the additional products needed to make this work for their specific application, but are you guys willing to share information regarding what parts you are currently using to make this system work?
Now Taking Orders!
Our port injection kit for the 1.5L Turbo L15B Honda Accord / Civic / CR-V & More permits the use of port injectors for additional fueling on high-powered engines by installing between the intake manifold and cylinder head. The port injectors are placed at a specific angle for proper fuel atomization. Please note that this does NOT replace the factory direct injection system.
Kit Includes:
*Users are responsible for sourcing an injector controller, wiring, fittings, fuel hose, etc.
- Anodized billet 6061 intake manifold adapter plate w/ injector ports
- Anodized billet 6061 fuel rail w/ (3) ports machined for -8AN ORB female threads & (1) port for 1/8" NPT female threads
- Anodized stand-offs
- All stainless hardware required for install
- 1/8" NPT sealed pipe plug
- (Optional injectors)
*Designed for use with Radium Engineering Fuel Damper (or similar)
*Due to the thickness of the Port Injection Kit intake manifold adapter plate, a custom or additional coupler hose is needed to connect the charge pipe to the throttle body. We are currently working on a solution for this as well.
*Designed around industry standard Bosch EV14 style injectors (48mm Height), which is commonly used by brands like Injector Dynamics, Deatschwerks, Fuel Injector Clinic, Fuel Injector Development, etc.
