Featured 1.5T PRL Motorsports 1.5T Civic Bolt-On Big Turbo Kit Upgrade Results
  1. PRL Motorsports
    PRL Motorsports Premium Performance Products
    Jan 26, 2017
    1,232
    3,364
    Export, PA
    #1 PRL Motorsports, Jun 1, 2018
    The results for our long awaited 2016+ Civic 1.5T Bolt-On Big Turbo Upgrade Kit are in! We have spent the past few weeks doing R&D with James from KTuner to figure out the necessary ECU tuning for a big turbo setup. Along the way we overcame quite a few hurdles, which required new background coding and experimenting with different tables/parameters.
    Our test subject’s (2017 Civic SI) setup is as follows:
    · 100% stock engine and transmission
    · 100% stock fuel system
    · PRL Motorsports Big Turbo Upgrade Kit w/ Cast wheel GT2860RS Disco Potato (.64 A/R and .86 A/R housings tested)
    · PRL Motorsports FMIC Kit w/ Charge Piping
    · PRL Motorsports Cobra Cold Air Intake (Street and Race MAF housings tested)
    · PRL Motorsports Front Pipe
    · Stock catback exhaust
    · Clutch Masters FX400 6-Puck Rigid Clutch
    · Stock flywheel
    · PRL Motorsports Braided Clutch Line
    One of our first obstacles for this big turbo upgrade was boost control. These cars are equipped with an electronic wastegate actuator for boost control from the factory. We kept this in mind when designing our kit for future possibility of integrating an electronic wastegate actuator. However, for the time being we decided to ditch this and utilize a manual boost controller to command desired boost pressures. KTuner worked to enable coding to make this possible.
    Once we figured out boost control we began tuning with our Street MAF housing , “small” .64 A/R turbine housing and 93 Octane pump gas to establish a rather simple/effective curve. However, after we began to make more power (low to mid 300 horsepower), we ran into another obstacle; fueling. James came to the rescue once again by working on background coding to allow us to overcome these “limitations.” We were able to put down 325 horsepower and 326 ft/lbs tq with this setup.
    Next, we decided to test out the “big” .86 A/R turbine housing to see what type of gains/losses can be seen with this switch. The “big” .86 A/R turbine housing was worth 29 horsepower at peak and 30+ horsepower at higher RPMs in comparison to the smaller .64 A/R turbine housing, bringing us to 354 horsepower and 359 ft/lbs tq. However, due to the nature of a larger housing, there was notable turbo lag of about 1000 RPMs. We were able to run more timing due to the increased efficiency of the larger turbine housing. Please keep in mind that this GT2860RS is the cheapest turbocharger option that we will be offering. The GTX2860R’s billet wheel will help with spool and top-end power, but we wanted to show what an economical turbocharger could do.
    .64 A/R housing compared to a .86 A/R housing with Street MAF housing
    To finish our testing we added our Race MAF to find an 8 horsepower gain throughout the midrange. Next we added some ethanol to gain even more through the entire powerband, netting us a whopping 368 horsepower and 323.24 ft/lbs tq! This just goes to show that the turbocharger is out of efficiency, which is no surprise from a turbo only rated to 360 horsepower.
    [​IMG]
    Due to the increased efficiency of this larger turbocharger, intercooler charge temps stayed cool the entire time with our intercooler!
    Now let’s put this all into perspective:
    Here is a graph showing the power output of a basic bolt-on car. This car was equipped with our catless downpipe/front pipe combo, Cobra CAI (Street MAF housing) and KTuner OTS preset 19.5/23 PSI maps.
    · Run 2 is 19.5 PSI and Run 4 is 23 PSI, which falls to 18-19 PSI at higher RPMs due to the nature of the small turbocharger.
    [​IMG]
    Here is a graph showing what our basic turbo kit (GT2860RS, small .64 A/R turbine housing and Street MAF housing) is capable of at the same/similar boost levels.
    · Run 7 is 18.5 PSI (as close as we could get to 19 PSI) and Run 12 is 23 PSI, which holds flat to redline
    [​IMG]
    We experienced 70+ horsepower and 74 ft/lbs tq gains at the same boost levels, which also carry to redline.
    Just to reiterate one more time, here is a stock car compared to a the bolt-on car and our turbo kit at ~19.5 PSI and 23 PSI.
    [​IMG]
    [​IMG]
    Here is a stock Civic compared to our turbo kit at 26 PSI with both the “small” .64 A/R and “large” .86 A/R turbine housing.
    [​IMG]
    We experienced 125+ horsepower and 110 ft/lb tq gains at 23 PSI in comparison to a 100% stock Civic!
    We also experienced 95+ horsepower and 110 ft/lb tq gains at 23 PSI in comparison to a basic bolt-on Civic!
    We finally got the chance to test out the GTX2867R GEN2 with "small" .64 A/R turbine housing and made numerous 390-398 whp and 370+ ft/lb tq hits! This little 1.5L engine is proving to be very stout thus far! We have a few more tricks up our sleeves to see if we can break the 400 whp barrier with this setup on Monday! ;) New power record anyone?!
    Here are some comparisons of the GT2860RS vs the GTX2867R GEN2. In our opinion, the GTX2860R GEN2 (that we didn't get to test) with the .64 A/R housing will be the best bang-for-the-buck setup for stock engine setups!
    These are astonishing gains from such a simple and cost-effective turbo setup. With that being said, customers will have the option to choose from quite a few different turbocharger and turbine housing options to suite their driving style and power goals. Options will vary from this cast wheel GT2860RS, to its billet-wheel-brother GTX2860R, all the way to the 650+ horsepower rated GEN2 GTX3071R.
    Our standard turbo kit will include:
    · Choice of turbocharger w/ turbine housing(s)
    · Wastegate actuator w/ associated hardware
    · Turbocharger adapter flange
    · Downpipe
    · Heatshield
    · Custom molded silicone pieces
    · TurboSmart 34mm Kompact Plumb Back Recirculating Bypass Valve
    · Hot side silicone pipe w/ silicone
    · Stainless clamps
    · Intake overpipe w/ PCV flange
    · Cobra cold air intake adapter silicone (Race or Street)
    · All gaskets and hardware needed for install
    · Optional FMIC Upgrade Kit
    · Optional Cobra Cold Air Intake System
    · Optional boost controller
    PRE-ORDER AVAILABLE NOW ON OUR SITE! :thumbsup:
    AREA, RyanK, FC1Dawn and 20 others thanked this.
  2. PNW_FC3
    PNW_FC3 Senior Member
    Oct 19, 2017
    139
    84
    Washington State
    Rae
    2017 Civic Si Coupe
    AWESOME!!!!
    Lume80 and PRL Motorsports thanked this.
  3. odinist
    odinist Senior Member
    Mar 27, 2018
    323
    290
    Occupation:
    IT/Dungeon Master
    OKC
    Matt
    2018 Aegean Blue Si Sedan
    Super dope!
    Lume80, PRL Motorsports and andyboyd102 thanked this.
  4. FR32H OJ
    FR32H OJ Senior Member
    May 15, 2018
    146
    77
    Rhode Island
    2016 Civic EX-T
    Sweet deal, looking forward to pricing
  5. dallasjhawk
    dallasjhawk Senior Member
    Oct 3, 2016
    3,923
    3,831
    Arlington, TX
    2016 Civic EX-T, 2004 Acura TSX
    Man y'all killing it again. Going to see some awesome 1/4 mi times soon!
  6. andyboyd102
    andyboyd102 Senior Member
    Dec 15, 2016
    546
    517
    Occupation:
    Transmission Power Grid/ Southern Company
    Alabama
    2017 Si
    GAME CHANGER!!!! This is why y'all get my money:nixon::dance:
  7. CrippleRipple
    CrippleRipple Senior Member
    May 11, 2018
    502
    277
    Kansas
    2018 Honda Civic Si (LSM)*SOLD* & 2018 Honda Accord Sport 2.0T (CBP)
    Wow! this is awesome! Amazing work and excited to see KTuner in the mix!
    This is perfect for a FWD street car with LSD! +300whp/ft-lbs is just perfect!
    Super happy with this platform!
    Can't wait to see pricing & options! I think I know where my money will be going.
  8. incutebus
    incutebus Senior Member
    Feb 21, 2018
    223
    60
    K
    FR-S
    What can we expect in terms of power on e85 with the smaller housing and the r instead of the rs? Also, can we use the rv6 downpipe?
  9. jramos4194
    jramos4194 New Member
    May 10, 2018
    Occupation:
    VIP Client Manager, Honda
    Deerfield Beach, Florida
    Jose
    2018 Honda Civic Si
    Loving the numbers can't wait for pre-orders and then install. :cool::cool:;)
  10. F30anderson843
    F30anderson843 Senior Member
    Oct 27, 2017
    132
    73
    Bluffton, Sc
    Justin
    2018 Civic Type R, 2014 BMW 335 EWG
    If I’m understanding this correctly this is all E85 based correct? Do you have an 93 oct numbers?
    Let me correct myself. On the video it appears those are E85 numbers. On the write it it mentioned 93oct for a base curve then ran into some fueling issues. So I’m assuming the numbers listed after that are also E85? Only reason I’m wanting to clarify is I do not have easy access to E85. So I would be using 93oct.
  11. CrippleRipple
    May 11, 2018
    502
    277
    Kansas
    Balls in your court 27WON :p
    Lume80 thanked this.
  12. OP
    PRL Motorsports
    Jan 26, 2017
    1,232
    3,364
    Export, PA
    All the numbers are 93 Except the last few pulls, 355whp 93 on a e blend with the same setup it made 368whp. Remember this is on the Base turbo option on our kit, changing from a cast wheel to a billet wheel will net even further gains.
    360glitch thanked this.
  13. OP
    PRL Motorsports
    Jan 26, 2017
    1,232
    3,364
    Export, PA
    this was 93 octane and e-30 numbers
  14. davemarco
    davemarco Senior Member
    Jun 3, 2017
    2,226
    1,239
    New York
    2019 Civic Type R (CBP), 2001 Honda Prelude (Premium White Pearl)
    Would love to see a comparison between the the cast and billet wheels. If the price is right, upgrading to the billet seems like a no brainer - more power for no additional turbo lag.
    Also, in reviewing the various Garrett turbo options, I noticed that there are newer versions of each. Is this base turbo option shown here the latest version of that particular turbo, or is there a newer version that can be purchased for more money that perhaps spools faster?
    05NBPDC5 and Lume80 thanked this.
  15. Two Step Performance
    Two Step Performance Senior Member
    Apr 24, 2018
    427
    655
    2017 Civic Si
    Way to go PRL! This exemplifies why we are a proud PRL dealer. We are looking forward to these kits becoming available!
    KramVT0215, Lume80 and 562Si thanked this.
