Presenting the AWE Exhaust Suite for the FC1/FC3 Civic Si. Available now!
  1. Josh/AWE
    Josh/AWE Senior Member
    Nov 4, 2019
    156
    134
    Philadelphia
    Josh
    CTR
    #1 Josh/AWE, Nov 14, 2019
    Sin for the Civic. Presenting the AWE Exhaust Suite for the Honda FC1/FC3 Civic Si, available now at AWECivic.com, EvasiveMotorsports.com, and participating AWE dealers around the world.
    • Integrated front pipe included in all editions
    • Proudly designed, engineered, and manufactured at AWE in the USA
    • Max gains of 6 hp and 1 ft-lbs of torque at the wheels
    • Touring Editions feature patented drone-canceling 180 Technology®, tuned specifically for the L15
    • Handcrafted from 3” CNC mandrel-bent, U.S.-sourced .065” wall T304L stainless steel
    • Bespoke stamped stainless steel trident tip merge
    • Modular tip designs allow easy interchangeability between dual and tri tip configurations
    • Less is more: clean, straight-through design maximizes performance
    • Direct bolt-on for factory-like simplicity
    • Triple or dual 4.5" double-walled slash-cut tips available in diamond black or chrome silver
    • Perfect fitment guaranteed
    • AWE No CEL guarantee
    • Lifetime warranty (one year on tip finishes)
    The Options
    Touring Edition Exhaust:
    At the intersection of sophistication and aggression lies the Touring Edition Exhaust. A full 3” T304L stainless steel downpipe-back configuration, the Touring Edition Exhaust is the perfect dose of steel for drivers looking for straight-pipe performance, a deep, sophisticated exhaust note, and zero drone at highway speeds.
    Featuring an integrated front pipe, bespoke mid pipe resonator, and AWE’s patented drone-canceling solution, 180 Technology®, the Touring Edition delivers a full-bodied, rasp-free L15 soundtrack unachieved by any of its peers. Under boost and heavy throttle, the Touring Edition screams. At highway speeds, drone-free within the cabin -- the best of both worlds. Perfectly engineered and packaged for the FC1/FC3 Civic Si, all backed by AWE No CEL and Perfect Fitment Guarantees.
    Sound Perfection: AWE 180 Technology™
    Perfect tone, compliments of AWE 180 Technology®.
    As exhaust gases exit the L15 engine and flow into an AWE 180 Technology® equipped resonator, they pass through strategically located ports, and into reflection chambers. Sound waves, carried by these exhaust gasses, bounce off the walls of the reflection chambers. By controlling the size and location of the ports and the chambers, we also control when the sound waves exit the chambers. The specific timing of when the reflected sound waves rejoin the main exhaust flow creates a one-hundred-and-eighty-degree out-of-phase sound wave that cancels out problematic frequencies. More on AWE 180 Technology® in the tab above.
    Track Edition Exhaust
    For those who like it raw and rowdy, the Track Edition is for you. The Track Edition shares the same integrated front pipe, bespoke mid pipe resonator, and precision engineering as its Touring Edition counterpart, minus AWE’s patented drone-canceling solution, 180 Technology®.
    In place of the 180 Technology® resonator in the rear lies a Track Edition straight section. As a result, this version is known to get (really) rowdy in mid range acceleration and deceleration, and may be too much for many. You’ve been warned.
    Important fitment notes:
    The Touring and Track Edition Exhausts include a full 3” front pipe. This front pipe is integrated into the design of the exhausts. AWE exhausts are not designed to mate with other aftermarket front pipes. Downpipes, on the other hand, should work just fine.
    Conversion Kits:
    We made it easy to convert between Track and Touring Editions, as well as dual and triple tip configurations, if you decide at a later date to change your volume or the aesthetic.
    Tip Options:
    The Touring and Track Edition Exhausts feature a modular tip design that allows drivers the choice of running double or triple 4.5” slash-cut tips via our bespoke stamped tip merges. With such interchangeability, a dual tip configuration can be converted into a tri-tip configuration (and vice-versa) within minutes via an AWE Tip Conversion Kit.
    Each exhaust comes complete with 4.5” double-walled, slash-cut tips available in chrome silver or diamond black, and feature a stamped AWE logo. All tips are individually adjustable, allowing depth into the bumper to be set according to personal taste.
    What’s in the box?
    Complete Touring or Track Edition Exhaust, two or three 4.5” double walled tips in desired finish, and all necessary hardware for installation.
    Data:
    86salmon thanked this.
  2. zhendexing
    zhendexing Senior Member
    Aug 26, 2018
    114
    118
    Chicago
    Dee
    2018 civic si coupe
    Any decibel rating ? Touring edition seems as loud as track edition
  3. OP
    Josh/AWE
    Nov 4, 2019
    156
    134
    Philadelphia
    Josh
    CTR
    Not at this time. The reason the Touring Edition's volume resembles the Track Edition's volume is because we do not use traditional packing methods for our patented drone-canceling 180 Technology® resonators.
    They are straight-through resonators with strategically placed ports to target drone-prone frequencies. These frequencies are then flipped onto themselves, and re-submitted into the exhaust stream. Straight pipe performance, sophisticated yet aggressive exhaust note, and no drone. The perfect package.
    zhendexing thanked this.
  4. Lagos
    Lagos Member
    May 26, 2018
    43
    Occupation:
    Automotive Engineer
    Philadelphia, PA
    2018 Civic Si
    Looks like a really nice exhaust!
    Does this fit both the Si sedan and coupe?
  5. OP
    Josh/AWE
    Nov 4, 2019
    156
    134
    Philadelphia
    Josh
    CTR
    It does!
  6. OP
    Josh/AWE
    Nov 4, 2019
    156
    134
    Philadelphia
    Josh
    CTR
    Released just in time for our annual holiday promotion.
    AWE BLACK FRIDAY IS ON! Get any of the newly released Civic systems at 15% off MSRP via AWECivic.com and Evasive Motorsports.
    display99x thanked this.
  7. OP
    Josh/AWE
    Nov 4, 2019
    156
    134
    Philadelphia
    Josh
    CTR
    It's time to secure your deal. Until December 3, receive 15% off MSRP on AWE Civic products, valid at participating dealers and at AWECivic.com.
  8. WingKing76
    WingKing76 Embrace the Grind, Because the Grind is Real!!!
    Jul 5, 2018
    130
    GA
    CJ
    2018 Civic Si
    Can I use a different front pipe with this exhaust?
  9. OP
    Josh/AWE
    Nov 4, 2019
    156
    134
    Philadelphia
    Josh
    CTR
    Negative. Offload your existing one and replace with the full gig :)
  10. WingKing76
    Jul 5, 2018
    130
    GA
    CJ
    2018 Civic Si
    Then the Rv6 down pipe will not fit. I would have to buy a new down pipe to get a full 3" exhaust.
  11. OP
    Josh/AWE
    Nov 4, 2019
    156
    134
    Philadelphia
    Josh
    CTR
    Not necessarily. The exhaust will work with any downpipe designed to work with the factory exhaust.
    Your DP looks very similar to the PRL DP, which we've had on our CTR (and what is used for our turboback product video example). Worked just fine and sounded fantastic.
