Sorry for late reply.. Thanks and I got the emblem at CorsportUSA.comNice wheels!
Where did you get your red H emblem?
Mine came with the rims and it's plasticQuestion for the class, I'm assuming everyone is running hub adapters for their aftermarket wheels? Did you go plastic or aluminum?
Safe is relative depending on some factors. If you are using QUALITY hubcentric adapters yes. Keep in mind adapters will add 20-30mm which will effectively make a 18x8 +50 wheel be + 20-30. So adding a adapter is just like adding a spacer, it will make the fitment more aggressive.Can I ask a question? Are lug adapters safe to use to convert 5x114.3 to 5x100?
Seen too many pics of folks wheels coming off when using adapters or spacers for me to ever consider it. If you do, DO NO GO CHEAP.Can I ask a question? Are lug adapters safe to use to convert 5x114.3 to 5x100?
keep in mind Subarus dont have a lot of fender room for lower offset setups. If your winter wheels are any lower than +50 you might have a bad time fitting them to a subaru with an adapter. May just be worth selling your steup and buying a new setup since quality adapters are like 200+ anyway.Considering a new car, Subaru however, my snow tires are 5x114.3 to fit my Civic.
On my old car, I went with aluminum, as I was told that plastic could melt if I tracked the car.Question for the class, I'm assuming everyone is running hub adapters for their aftermarket wheels? Did you go plastic or aluminum?
