Possible KTuner issue
BubbzWasHere
Kaleb
Denver, CO
2018 Civic Hatchback Sport 6mt
I have the KTuner v1.2 and an Amazon Fire as a gauge display. Things have worked great for awhile. The past couple of days though, I've noticed the display lagging and not really reading real time like is usually does. I also noticed tonight, that when it is doing this the status light is slowly blinking white. I read in the online help that white blinking is supposed to mean that onboard logging is recording. I did a log once, but it has been awhile, and this lagging has just started happening recently. Anyone had this happen to them, or have any ideas what to check? I would shoot an email to KTuner, but the website says they are closed for SEMA until 11/5.
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
Seems like your Amazon fire is the cuplrit and not Ktuner
Cscott_xGen
Connor
Arizona
2017 Civic SI
Make sure your Ktuner software is up to date. You can download the latest version of the software by reinstalling it on your computer
BubbzWasHere
BubbzWasHere
Kaleb
Denver, CO
I was wondering about that too. I just wonder mainly if the slow blinking white light on the KTuner has a different meaning other than onboard logging.
BubbzWasHere
BubbzWasHere
Kaleb
Denver, CO
Probably something I should have tried first. I'll do that this weekend and see if anything changes.
I also failed to mention above, sometimes everything seems to work perfectly fine. Green light quick blink on the Ktuner, gauges reading seemingly real time. Then I look again and it's frozen. I would definitely think tablet, if the status light on the unit itself weren't doing something different than usual
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
If you do have on board logging enabled and it's filled up all the way this can cause delays when it starts or stops recording. Connect with the software, check how many logs you have in on board logging, and delete logs or disable it if necessary!
BubbzWasHere
BubbzWasHere
Kaleb
Denver, CO
That there may have been it. 98% full...
I didn't realize I had turned it on and left it on.
