SoSublime
- Apr 1, 2017
- 14
- 135
- 99
- United States, California
- 2017 Civic EX-T
- Vehicle Showcase
Hey guys.
I just wanted to let you know, if you are having problems with your A/C with the symptoms of cold A/C during moderate temperature days (Below 85-90F) but warm A/C on hot days, you do infact have an issue.
The symptoms are cold A/C while moving such as freeway driving. City driving, idle, or stop/go is the prime occurance when you will start to get ambient temp A/C, warm A/C, mugginess, or possible odor.
The probable cause of this is most likely the condensor unit, or switch placement (switch becomes wet, or covered in grease/grime, location of switch is front of the engine bay, passenger side all the way down by the plastic scrape plate, marked with a blue dot on mine). Honda switched to a new refrigerant called 1234YF for EPA reasons leaving the old 134 behind, new refrigerants require new compressor designs, and new designs have the potential to fail alot.
As of yet, there is NO official fix. Your car will be leak tested, and an attempt to recharge your unit will be preformed (another symptom is LOW freon result returning during the leak test). The best solution now is to visit your dealership of choice, and have them attempt to solve the issue. At the very least get it logged and noted you have the 1.5L A/C issue so Honda must pay attention to it and we can get a real fix sooner.
I will update this thread with more information as I get it.
