There is no Fram part number for the engine air filter since they haven't released one.What is the fram engine air filter Part number? Anyone can direct me to the DIY guide link.
Diy. Pop hood.. Locate airbox. Directly behind driver side headlamp. And in front of fuse box (wich is in front of battery.. Remove 3 metal clips. Remove bu pulling up amd out to the side.. Remove filter and replace with new one.. Reverse the directions given here to finish..What is the fram engine air filter Part number? Anyone can direct me to the DIY guide link.
I'd add,Diy. Pop hood.. Locate airbox. Directly behind driver side headlamp. And in front of fuse box (wich is in front of battery.. Remove 3 metal clips. Remove bu pulling up amd out to the side.. Remove filter and replace with new one.. Reverse the directions given here to finish..
Cabin filter.. Drop glove box.. Squeeze 2 ends of glove box and lower glove box further. Behind glove box push 2 tabs on each side inwards and pull out.. Replace filter and reverse instructions..
Only if the filter looks dirty even if the MM says to replace. But since the high quality OEM filter is cheap I'll just drop in a new one when the MM asks for it.Do you replace them when the maintenance minder comes up or after a certain mileage?
I don't know about other models, but my ext has no clips, the air box is held on with 4 screws.Diy. Pop hood.. Locate airbox. Directly behind driver side headlamp. And in front of fuse box (wich is in front of battery.. Remove 3 metal clips. Remove bu pulling up amd out to the side.. Remove filter and replace with new one.. Reverse the directions given here to finish..
This is true of my 18 Hatchback EX as well - four screws, no clips. The screws are soft, so be careful not to strip them.I don't know about other models, but my ext has no clips, the air box is held on with 4 screws.
