Domsdad324
- Randel
- Aug 12, 2018
- 11
- 0
- brunswick GA
- 2018 energy green civic SI
Awesome thanks for the help. I’d love to see your civic.In my coupe, I have my dual 12" ported enclosure rear facing.
In my experience, rear facing gives a little more output into the cabin when windows are open, and
front facing sometimes has a little more response (or less "boominess").
My trunk doesn't really rattle at full tilt. Keep in mind I'm probably playing at around 130 db.
I feel more impact while rear facing rather than forward facing.
Supposedly, if you have a hatch, upfacing subs, rear facing ports gives the most output.
Years ago, I had a co-worker run dual 18" digital design 9500 series subs up-facing with three 4" diameter ports into the hatch door.
It was absolutely insane and difficult to breathe during long bass notes and the kick punches were heart stopping.
I used an "add-a-circuit" fuse tap plugged into a circuit that is typically off while the engine is off.
I'm fairly certain I probably tapped it into the ECU circuit because ECU is usually off even while ACC is on.
This, I ran to the battery isolator and the amp (as well as my air-ride suspension).
