PERRIN Intercooler for the Type-R (Test Results Inside)
  1. PERRIN_Jeff
    PERRIN_Jeff Member
    Apr 19, 2018
    85
    Hillsboro, Oregon
    2017 Civic Si Coupe
    We all know intercoolers make power but how much? When is it good to install one? Should this be your first mod? Do I need to make permanent mods to the car to install it?
    The answers to the questions are quite different if we were talking about Subaru STI’s (the car we have spent most of our lives tuning) versus the new Honda Civic Type-R. We have always recommended installing intercoolers after you have done most of the normal bolt on items, but this time around, we think it could be done as one of the first mods.
    Why Do You Want An Aftermarket Intercooler?
    The stock intercooler on these cars (as well as most cars) are designed to match the power of the engine and not much more than that. Taking that one step further, they are rarely designed to work under track conditions where the charge temps entering the intercooler are much hotter for a longer period of time. When HP is increased (with ECU Tuning and or other parts) and cars are driven at their limits, the OEM intercooler can’t keep up and charge temps significantly increase, and the full power potential is not realized. Larger intercoolers (when designed properly) reduce charge temps to a reasonable level and reduce air flow restrictions allowing tuners to take full advantage of things like increased ignition timing, more boost, leaner AFR’s and so on. Properly designed intercoolers are vital to any modern-day turbocharged engine and in the case of the Civic Type-R, might be the best single mod overall next to an ECU tune.
    Testing Of The PERRIN Intercooler
    We did two main tests with our car, with stock ECU tune and with an aftermarket ECU tune. This gives real world results for the most commonly found setups we see customers with. Our test car is my personal CTR (Shop car is always torn apart) and the only modification it has is our 3” Catback exhaust with front pipe. The first thing we do is a bunch of runs to get the car up to temp and then a few runs to create the baseline. In the case of this, we ran the car about 20 times before we found consistent HP levels. We then swapped the intercooler and did a bunch more runs. The results below are showing what we found consistently which was a 10-WHP gain at the upper RPMs. (If you are caught up on our ACT Mod thread, you will find all the results below (stock and otherwise) are with that mod done. This is very important to ensure consistency before and after) THREAD FOUND HERE
    One limiting factor to these results (but also why it was very consistent run to run), is the ECU. The ECU was limiting TQ and changing boost all over the place to maintain this same result. Most of this has to do with air temp readings from the intake as well as the manifold temp sensor (ACT or Air Charge Temp). Some evidence of this can be seen from the graph below, the boost has very strange dips, without change to power. If we showed you all the runs you would see it varies by almost 3000RPM.
    Next up is the same test on the same car but with a "Ktuner Stage 1 w/downpipe" tune on the car. After the flash, we ran it just like before, then swapped the intercooler and did a few more runs. The results were the 20Wheel HP you see below. The best thing is this was very consistent over and over again.
    Just to go over the numbers shown. We are not showing the best and worst numbers we found, we are showing the most consistent numbers found between both setups. Meaning we did see more TQ and HP on a couple runs with our intercooler and even lower numbers with the stock intercooler, but don’t want to skew the numbers just to make the intercooler look better.
    The above graph is showing the different groupings and you can see the stock intercooler started at 320WHP and quickly dropped to 300WHP (actually, even more that we aren’t showing). The max charge temp we saw at 7000 RPM was 161F, so no wonder why it kept losing power. The compare our FMIC and how it settled at around 325WHP run after run. Max charge temps we saw with the PERRIN Intercooler is 107F and the recovery temps were much better.
    The graph above is showing the runs with the stock intercooler and our intercooler side by side. The data is showing the charge temps along with a bunch of other things.
    Reasons for Why It Is Designed The Way It Is
    Just like we do with other cars, we wanted to make the core as large as possible in every way except one direction, which is depth. We see far too often cores are made really deep (front to back direction) and while this can have some good results initially when everything is cold, they very quickly become less effective once under extreme conditions. The reason is, the ambient air flowing through the core gets heated up and slows down as it gets to the back of it. This can create a less effective core toward the rear, kind of like turning it into a thinner core. We have always found that 4” is a good thickness limit on cores but on the CTR, this would end up limiting our actual volume and frontal surface area because we couldn’t go quite as tall as we wanted and still leave a good amount of room behind it for air flow.
    Lastly, we lowered the intercooler down as much as we could to take advantage of two things. First is to utilize the opening of the bumper more and then to ensure the charge pipes are entering the middle of the core as much as we could. This helps distribute the hot air evenly through the core which makes it more effective at removing heat.
    On some vehicles there are major modifications required (new bumper beams, cutting of the bumper skin…) to install larger front mount intercoolers. In our case, only a small modification to the lower plastic splash guard is required. Something that doesn’t affect how your car looks when it is returned to stock, but also something we wanted to mention so customers are aware of what they will encounter during install.
    Stats
    OEM Core size 26.77” x 5.62” x 2.52” Volume 379 cu-in Cooling Surface area 150sq-in
    PERRIN Core size 26.00” x 8.50” x 3.15” Volume 696 cu-in Cooling Surface area 221sq-in
    Compared to the competition, we have a larger volume and larger surface area compared to most. One has larger volume (but too thick in our opinion) but they also have a smaller surface area. One has more surface area (but blocked by the bumper beam) but is a smaller volume. We feel we have the best blend of volume and surface and it shows with our HP results.
    The end tanks were designed to be cast which allows for smooth airflow from the charge pipes to the core. While sheet metal tanks are lighter and cheaper to make, the investment to make them from a casting pays off with better performance. Lastly, we made sure the tanks work with the OEM o-rings. This is important as they are designed to last the life of the car, and they have a special shape that allows for better sealing than a standard round O-ring. you can see the pic below showing the groove as well as the o-ring sitting there.
    Just For Fun Comparison
    In our world we deal with lots of Subaru stuff and have tuned lots of them of course. After we were all done with testing the FMIC (and some other upcoming parts) I pulled up some graphs of STI’s we have done and found some very interesting things.
    The setup between the STI and Civic Type-R represents what we see typical customers doing to their cars and also similar money spent.
    CTR Parts Installed
    OEM Downpipe
    PERRIN 3” Catback with Front pipe $1699
    PERRIN FMIC $699
    Ktuner Flash running the OTS Stage 1 w/downpipe tune for 91 oct. $699
    Total Cost of parts $3097
    STI Parts Installed
    PERRIN 3” Highflow Cat Downpipe $599
    PERRIN 3” Catback $1250
    Cobb Accessport Running PERRIN Stage 2 Map $695
    PERRIN Header $1000
    Total Cost of Parts $3544
    You can see that the peak TQ and WHP numbers are higher on the Civic, but what is most impressive is the area under the curve. At 6000RPM the Civic makes 50ft-lbs more TQ and 60WHP more! It’s no wonder why the Civic feels faster than the STI while driving them above 3500RPM, it's because it IS faster!
    Conclusion
    Buy PERRIN FMIC, and gain 20+WHP :)
  2. FK8_K20c1
    FK8_K20c1 HONDA The Power of Earth Dreams Technology!
    Jan 12, 2018
    838
    509
    Occupation:
    Engineer
    Indiana
    MKV R32, FK8 Type R
    Food for though. The IAT1/ACT sensor measures boost pressure and temperature. Hence why you saw the dip on your boost graph. If the ecu registers a deep change on cold temps it will bring down the boost. The other way around if it registers hot air it will up the boost to a limit.
  3. jonnys_honda
    jonnys_honda Senior Member
    Mar 1, 2017
    1,862
    2,706
    Irvine, CA
    Jonny
    2017 Civic Type R #1288
    Thanks for the thorough testing! Always good to see ongoing developments for the FK8
    Meat Hammer thanked this.
  4. OP
    PERRIN_Jeff
    PERRIN_Jeff Member
    Apr 19, 2018
    85
    Hillsboro, Oregon
    2017 Civic Si Coupe
    Yup, for sure that is why. Its part of the TQ monitoring/controlling going on. It's crazy they put so much effort into developing this and make it difficult for ECU tuners (Hondata and Ktuner). But its also pretty cool how well it works to maintain a consistent HP level in all conditions.
    Meat Hammer and FK8_K20c1 thanked this.
  5. FK8_K20c1
    Jan 12, 2018
    838
    509
    Occupation:
    Engineer
    Indiana
    MKV R32, FK8 Type R
    Yes it’s impressive.
  6. alejandroads123
    alejandroads123 Senior Member
    Apr 30, 2018
    503
    166
    Daniel
    Civic type R
    I would love to see a picture from the top (how thick is it) and if this possible compared with the oem side by side (from top view)
  7. OP
    PERRIN_Jeff
    PERRIN_Jeff Member
    Apr 19, 2018
    85
    Hillsboro, Oregon
    2017 Civic Si Coupe
    Here you go!
    I took a couple of quick pics for you. One is the cores lined up front to back. The other picture has it lined up top to bottom, but the OEM core is raised up a bit, making ours look a little shorter than it really is.
  8. alejandroads123
    Apr 30, 2018
    503
    166
    Daniel
    Civic type R
    Looks very nice !
  9. davemarco
    davemarco Senior Member
    Jun 3, 2017
    2,138
    1,211
    New York
    2019 Civic Type R (CBP), 2001 Honda Prelude (Premium White Pearl)
    Are there plans for an annodized black version? I have a murdered out build that is itching for a black/charcoal intercooler. :)
  10. chanman
    chanman Member
    Jun 13, 2019
    26
    562/949
    Kevin
    2019 Civic Si Sedan
    Any plans for the Si as well? :)
  11. Ctr1
    Ctr1 Member
    Apr 28, 2019
    35
    Washington
    18 CTR, 03 IS300, 94 EG, 08 Highlander
    @PERRIN_Jeff. Sorry my question is not related to the intercooler but the oil cooler catch my eyes. Is it a prototype dual oil cooler? Will this release to the public? Thank you!
  12. TypeSiR
    TypeSiR Senior Member
    May 15, 2017
    1,096
    715
    Occupation:
    Car Driver
    1.5T Civic, CTR, MX5
    Good catch. Same question. Very interested.
  13. GraphiteAZ
    GraphiteAZ Senior Member
    Sep 8, 2019
    118
    41
    Tucson, AZ
    Civic
    Do you have an average temp drop between the hot side and cold side? I know the OEM intercooler suffers with heat soak quickly.
  14. OP
    PERRIN_Jeff
    PERRIN_Jeff Member
    Apr 19, 2018
    85
    Hillsboro, Oregon
    2017 Civic Si Coupe
    We won't do anodized ones, but powdercoated for sure. We started with silver only as we felt that is what people wanted. If you are looking for a black one, let me know and I will look into getting done for you at no extra charge!
    This will be next, just not sure when that will happen. Most likely sometime early next year.
    I do not have the pre-intercooler temps to add to our above data, but based on a few calculations, this would be in the 325F peak range. Since we can measure the intercooler outlet temps, and the dyno runs were making the same boost before and after, that temp drop of 50-60F is what we will use for data as to how well it is rejecting heat.
    Meat Hammer, chanman and davemarco thanked this.
  15. OP
    PERRIN_Jeff
    PERRIN_Jeff Member
    Apr 19, 2018
    85
    Hillsboro, Oregon
    2017 Civic Si Coupe
    Good eye!!
    What you are seeing is a prototype engine oil cooler and transmission cooler. I am not sure we will end up making the tranny cooler version. I have found that under extreme conditions, that adding an engine oil cooler helps relieve enough stress from the radiator's cooling duties that the tranny cooler may not be needed. Then adding an additional cooling method (being vague on purpose) for the engine seems to eliminate that need. But we have the parts to be able to build them and it is something we could be if someone asks. Then engine oil cooler kit is all done and just wrapping up some instructions, then you will see the launch very soon.
