ipeefreely
- Will
- Jun 4, 2018
- 22
- 586
- 939
- Bay Area, California
- 2017 Ford Raptor / 2019 CTR
- #46
Chapter 12 - Brakes - Girodisc front rotors, endless MX72 pads all around.
With my quickjack and extension ramps working, I set about upgrading the brakes on this car. Ordered a set of Girodisc front rotors and Endless MX72 pads. I didn't do much research on the rotors as I just followed another owner's advice but the pads I have used in my all previous builds and i love them. They're probably the only pad that gives me the stopping power I want WITHOUT a massive amount of brake squeal. The only downside is that they're expensive as hell.
Never did a brake job before so I had to google up on instructions. Followed this video:
Installation was pretty straight forward. The rears were a little more complicated though and I hit a snag as the passenger side was not going in (i was able to use some force to push in the driver's side rear). Ended up having to pick up a piston compression tool.
The tool is NOT that user friendly and is a bit confusing when you don't read the instructions. Namely the part where each compression tool had a different orientation for tightening / loosening it. For example, one of the tools might be a counterclockwise rotation to loosen while it's the opposite for the other one.
With the piston properly compressed, I was able to easily slide the caliper back on. Hit another snag when i realized I had disconnected my e brake plug. Took me awhile to figure that one out as I had switched the wires around when reconnecting it.
Pictures:
Front:
Side by side comparison: (stocks on the left):
Rears:
Tips for installing these parts:
- Make sure you have a piston compression tool on hand
- Make sure you torque the bolts back to spec
- Read ALL the instructions on the tools
- Having a rubber malet around helps too
Impressions:
I finally had the chance to drive my car around for a bit and stopping power feels very nice. There is also no brake squeal. Which is awesome. Next step would be to test it at the track.
Pictures:
Front:
Rears:
Impressions:
