P0035 on 16 Civic Touring
David16touring
Waukegan IL
2016 Civic touring, 2014 Mazda CX-5 Touring FWD.
Hey everyone. Just like the title says,I have a P0035 code. I have a 16 civic touring with about 67k miles on it. I’ve been tuned on Ktuner 16.5/21 tune for about 6 months now. I was driving on the highway one day, cruising at about 85-90, and BOOM the light goes on, car can’t hit boost, all the warning lights come on. I pull over to a gas station and I was able to clear the code. Went away for about 2-3 days and it came back on again. I can clear it and the car will drive like normal for that one drive but will come back the next time I either turn the car or just barely get into boost, no specific condition is needed for the code, once it came on when I was barely pulling out of my neighborhood at about 10mph. Other times I can make it a few miles before it comes on. I’ve looked on the forums here(nobody seems to have a clear answer on what their fix was) and have noticed some specific wire harness locations that are prone to breaking, I’ve checked my connections and harnesses, they seem to be okay. At least from what I can see. Anyone have any clue as to what it might be? I’m thinking it’s the boost solenoid that’s bolted to the turbo assembly but cannot find a proper way to test it since it works just fine when I clear the code. Any ideas/suggestions would be greatly appreciated!!!
Mods on the car are PRL catted downpipe, Stage 1 PRL filter and intake, Two step performance Flex fuel kit, Ktuner V2.
Hollywoo0220
RJ
WA
Other checks would be the Bypass Valve. Check the small hose and the unit itself. Not an expensive part BTW. Maybe consider an after market version for a better release.???
David16touring
David16touring
Waukegan IL
Hose to the valve is good. Aftermarket bov?? I’ve heard not so good things
Hollywoo0220
RJ
WA
David16touring
David16touring
Waukegan IL
Haven’t seen too many aftermarket bypass valves tbh
Enday24si
Ayinde
Civic si
Enday24si
Ayinde
Civic si
Honda Civic 10th gen P0035 on 16 Civic Touring 3BED545A-6B0A-4741-8276-335EED74864E
Enday24si
Ayinde
Civic si
The green wire is the problem for code p0035 it looks intact from the outside but inside the wire isn’t connected and is giving boost shortage cut it make the wires connect and you’ll be fine
rollerchester
Stafford, VA
Honda CIvic LX 2016
I'm having this problem as of now. Apparently reflashing my car takes away the error for couple of hours and then comes back. What exactly did you do?
rollerchester
Stafford, VA
Honda CIvic LX 2016
