Opinions on Sound System Set Up *now installing*
x6369x
2017 Civic EX Sedan
I ran my 1/0 next to the large boot behind the brake pedal. This is the only location such a big cable would fit through. This is only temporary since I believe my best options is to drill a hole into the firewall and add a grommet large enough.
I'm slowly installing my amp/sub and almost done with the sound deadening.
I ended up drilling a hole through the firewall and using a grommet for my 1/0.
Honda Civic 10th gen Opinions on Sound System Set Up *now installing* 20170614-202356-nb
How did you connect your 1/0 to the battery? Can you post a pic?
I don't want to cut off the OEM battery terminal and was thinking about getting a KnuKonceptz Ultimate Positive Battery Terminal:
https://www.amazon.com/KnuKonceptz-Ultimate-Positive-Battery-Terminal/dp/B00JK9FT1C
Honda Civic 10th gen Opinions on Sound System Set Up *now installing* 81EnQXfHDFL._SX425_
bajaivan
Perris, CA
2016 Civic EX-L, 2013 F250 Diesel
That looks good for the hole. I got the terminal from knuconcepts.
Honda Civic 10th gen Opinions on Sound System Set Up *now installing* 20170623_205800
Honda Civic 10th gen Opinions on Sound System Set Up *now installing* 20170623_205827
bajaivan
Perris, CA
I forgot to mention that I did have to grind on the original car terminal to make it flat. That way the 1/0 terminal could fit flush against it.
Here is a little better pic of the sub:
Honda Civic 10th gen Opinions on Sound System Set Up *now installing* 20170623_205913
M1KL83
Michael
Ontario, Canada
2018 Civic Hatchback LX 6MT, 2002 Honda Accord SE 5MT
Sorry for he way late response. I ran my 1/0 next to the large boot behind the brake pedal. This is the only location such a big cable would fit through. This is only temporary since I believe my best options is to drill a hole into the firewall and add a grommet large enough.
I just installed the new box yesterday. I can't even explain what a big difference in sound between the cheap box and the custom box is. It's everything I wanted my system to sound like and more. The highs, mids and bass are all there. Now the only thing that bothers me is not being able to adjust any of the basic EQ settings while listening to music through Android auto. I might have to install an external EQ.
Here is s shitty pic of the new box. More pics to come later.
Any pictures available of how you got your 1/0 AWG power wire thru the firewall? I'm looking to do the same.
Cheers!
M1KL83
Michael
Ontario, Canada
All I would need is the colour of the wires for the rear speakers + the amp remote which I'm guessing is white and blue.
Did you ever figure out I'd the wires are the same colours fir the hatchbacks versus sedans?
I have the 8 speaker hatchback, so the diagram above isn't for it exactly but I'm guessing it's not far off.
**Edit** I can confirm that the front door and sail tweeter wire colours are the same for the hatchback 8 speaker system as in the sedan diagram posted earlier in the thread.
thatlilwhiteone
ne
18 civicsi SOLD
This a coupe? How'd you get the bigger speakers in the rear?
bajaivan
Perris, CA
My bass craving has now surpassed my current setup. I'm now in the process of doing the big 3. I'm also adding a second battery in the trunk. A northstar agm 31. New subs will be 3 sundown x-8 v.3's. At 1
33 ohms I should be pushing around 1700 watts rms to the 3 8's. Getting the alternator out is not as easy as the older civics.
Honda Civic 10th gen Opinions on Sound System Set Up *now installing* 20190112_132858
Honda Civic 10th gen Opinions on Sound System Set Up *now installing* 20190112_165637
Honda Civic 10th gen Opinions on Sound System Set Up *now installing* 20190112_165758
Honda Civic 10th gen Opinions on Sound System Set Up *now installing* 20190112_132515
slothin49
Elijah
Honolulu, HI
2019 Civic Sport Sedan (Leased)
Goodbye trunk!
Sorry to revive this a few months later, but how does your car seem to be running with such large system? You're using the stock alternator with just a big 3 upgrade and 2nd battery right?
bajaivan
Perris, CA
That is correct. Actually sold the car now, but I had no issues with that setup. Worked great and batteries stayed charged.
bajaivan
Perris, CA
Did you sell it with all your components?
I sold it with everything, except the subwoofer setup. Then I sold the subwoofers to a friend. I still kept the amp. I plan on using it in my new Raptor.
