Old or New TPMS with new wheels?
  1. redcivic19x
    redcivic19x Senior Member
    Oct 20, 2019
    63
    FL
    Josh
    2019 Honda Civic SI Sedan
    I'm thinking about buying the Enkei TS10’s 18x8 (I want to retain stock wheels) and one of the options was whether or not to buy a new TPMS system. I’d like to retain the old one if possible because it has less than 10k on the original rim and tires, but I’ve heard it’s a good idea to get new TPMS with new wheels because of the sealant used.
    Has anyone used their old TPMS with new wheels? Or is it just recommended to go brand new? Thanks!
  2. gtman
    gtman Senior Member
    Oct 27, 2015
    6,639
    7,576
    Occupation:
    CivicX addict
    U S of A
    2017 Cosmic Blue Civic EX-L
    #2 gtman, Feb 13, 2020
    We don't have the traditional TPMS sensors inside the wheel. No need to purchase at all. Just reset (calibrate) the system after your new install.
    redcivic19x, bugboy32337 and EconoBox thanked this.
  3. EconoBox
    EconoBox Member
    Feb 10, 2020
    37
    Josh
    2020 Civic Si Sedan
    Just like gtman said this system doesn't actually use a sensor in each wheel. You'll just need to calibrate the system once you change your setup.
    redcivic19x thanked this.
  4. EconoBox
    EconoBox Member
    Feb 10, 2020
    37
    Josh
    2020 Civic Si Sedan
    And how to calibrate the system once you get those new wheels.
  5. bugboy32337
    bugboy32337 Senior Member
    Jun 10, 2019
    281
    264
    Occupation:
    Draftsman
    Tallahassee
    2019 Civic Si Coupe (MSM)
    The TPMS for the GenX Civics is done by the cars computer, comparing the number of rotations each wheel makes.
    As the tire goes flat, it effectively reduces the diameter of the tire ... and thus, increases the rate that it rotates.
    The computer compares the number of rotations the deflating tire makes, with the number of rotations the other tires are making.
    Once the discrepancy exceeds a predetermined threshold, the computer alerts you of a tire going flat.
    I hope this helps your understanding.
    arpypat and redcivic19x thanked this.
  6. OP
    redcivic19x
    Oct 20, 2019
    63
    FL
    Josh
    Just wanted to say thank you to everyone that responded so quickly. You guys just helped save me $150. Definitely good info to know.
    Anything else I should keep in mind when it comes to buying new wheels for the 10th gen?
  7. EconoBox
    EconoBox Member
    Feb 10, 2020
    37
    Josh
    2020 Civic Si Sedan
    Just look around the wheel threads to get ideas for sizes. Don't go too crazy and you can fit some pretty nice wheel and tire sizes without rubbing or hacking up the car.
  8. arpypat
    arpypat Senior Member
    Jun 29, 2019
    409
    396
    Occupation:
    Electrical Engineer
    Kansas City
    Arpan
    2019 Civic Si Sedan ABM
    Since you mentioned wanting to buy 18x8 wheels, I'd say also go for OEM tire size, 235/40r18, for your new wheels. I'd recommend staying in the +35-50 range for wheel offset. OEM wheels are +50.
  9. OP
    redcivic19x
    Oct 20, 2019
    63
    FL
    Josh
    Yea once I have some more mileage (and money) I’m going to upgrade the tires and go with the same size. I don’t want to do anything crazy because it’s my daily driver and want to keep exact OEM sizes if possible. Oh ok good, the TS10s are +50
  10. OP
    redcivic19x
    Oct 20, 2019
    63
    FL
    Josh
    Will I need aftermarket lug nuts?
  11. EconoBox
    EconoBox Member
    Feb 10, 2020
    37
    Josh
    2020 Civic Si Sedan
    #11 EconoBox, Feb 14, 2020
    Yes, you will need aftermarket lug nuts. The oem lug nuts are a ball seat type and Enkeis will use "tuner" lugs. Which are 60 degree tapered seat. Muteki makes a nice steel closed end set that I've had good experiences with.
    I would also recommend getting hub centric rings.
    bugboy32337 thanked this.
  12. OP
    redcivic19x
    Oct 20, 2019
    63
    FL
    Josh
    Thank you for the suggestion! I figured I wouldn't need the hub centric rings since the wheel was the same size as oem. But I definitely don't want any shaky vibrations going to my wheel so I'll definitely get them if you think they will help. Any idea what size rings I'd need?
  13. EconoBox
    EconoBox Member
    Feb 10, 2020
    37
    Josh
    2020 Civic Si Sedan
    You can do more research into hub centric vs lug centric if you want. Basically you want the wheel centered to the hub and the load of the wheel to be shared with the hub and lug nuts not just relying on lug nuts to do all of the work. But hub centric rings are cheap and make the aftermarket wheels fit to the hub like the OEM wheels.
    Civic is 64.1mm center bore, Enkei TS-10 is 72.6mm center bore.
  14. OP
    redcivic19x
    Oct 20, 2019
    63
    FL
    Josh
    Oh okay so I would need a 8.5 mm ring, correct?
  15. EconoBox
    EconoBox Member
    Feb 10, 2020
    37
    Josh
    2020 Civic Si Sedan
