Oil dilution and body style
Which body style do you have with oil dilution problems?
  • Total voters
  • Poll closed .
Lifesabeach
Uk
Civic Sport Hatchback 1.5 T
Guys I am just trying to work out if th US built engines are prone to oil dilution more/less in the coupe and sedan than the UK built engines in the hatch. Please vote with the body style of your car if you are having dilution issues.
Many Thanks
latole
Vaudreuil,Quebec ,Canada
https://amp.cnn.com/cnn/2018/10/05/cars/consumer-reports-honda-cr-v-engine-trouble/index.html
CVR use sams 1.5 L engine as a forum member write
Link said ;
In some CR-Vs, gasoline can leak into the SUV's engine oil. That can eventually cause the engine to lose power or stall completely. Several Consumer Reports subscribers reported the issue which has also been the subject of of dozens of complaints to the National Highway Traffic Safety Administration, according to the magazine. Many more owners have complained of the problem in online forums, Consumer Reports said.
SI_honda_2k17
Can
Honda civic si
Coupe
Built in canada
No fuel dilution, oil level stays normal sunce the begining (15500km)
But i don’t drive a lot in traffic, mostly highway
Lifesabeach
Lifesabeach
Uk
Im just trying to establish whether UK or US built engines are more/less susceptible to oil dilution and seeing as the hatchback is built in the UK with UK built engines it gives a us something to judge which engines may be more or less likely to suffer from dilution. Its just a theory
SI_honda_2k17
Can
Honda civic si
All the 1.5 Turbo civic have the problem potentially
The daily milleage and temperature are the main factor that determine if the problem will appear
Gruber
Mark
TN
The hatchbacks from the UK have engines built in Thailand.
I have probably some fuel dilution but I don't have an issue with it :) so I don't know how to vote....
I'm not sure how much if at all the oil was overfilled from factory. I'm looking at it now after the first oil change, and waiting for winter, but I still don't expect to be ever worrying about it.
Lifesabeach
Lifesabeach
Uk
Honda UK told a friend of mine that all the hatchback engines are made in the UK? Now Im confused is there any evidence as to where they are made?
Scott_ATL
Scott
Atlanta, GA, USA
2018 Civic HB Sport Touring, 2012 Ford Fusion Hybrid
I just checked my window sticker for my 2018 HB Sport Touring. It states final assembly: Swindon, UK; Origin of Engine: Thailand; Transmission: Japan. And according to the sticker in the driver's door jamb mine was built June, 2018 (6/18).
All hatches are assembled at Swindon but to my knowledge the engines in the hatch are imported from Thailand.
Mikeybc
Northern Ontario
2017 Civic Coupe EX-T, 2015 Nissan Murano
Coupe
Built in canada
Same here but with over 50,000 km
IDriveACivic
J
2017 Civic Touring Sedan
This topic is frustrating to follow because:
1a. What counts as "having oi/fuel dilution problem"? Documented used oil analysis? People jumping into conclusions (with a dash of confirmation bias) from sniffing the dip stick? Unscientific reading of the dipstick level?
1b. Dipstick being hard to read.
2. Honda corporate seems to be dragging their feet when it comes to communication.
3. People regurgitating the same rumors over and over again.
Anyway, I can't vote because though my sedan is built in Canada, I have not experienced any issues. FWIW, my drives are mostly 20 - 30 minutes with some highway stretches.
Fk8 4343
Greg
VA
17' Civic Type R, 17' CR-V Touring
I wonder if Honda will recommend a higher oil grade for the 1.5 turbo. Just a thought.
Honda can't endorse a more viscous oil in the US. 0W-20 was used to calculate emissions for CAFE and can't be officially changed.
This is from the UK/Ireland owners guide and has international oil specs. 0W-30, 5W-30, and 10W-30 are ok as long as the brand is API certified. note that "Except European Models" doesn't mean US.
Honda Civic 10th gen Oil dilution and body style Screen Shot 2018-10-07 at 9.46.13 PM
