Ohlins For Civic Type-R FK8 - SakeBomb Garage
  1. SakeBomb Garage
    CivicX Basic Sponsor
    Dec 19, 2018
    Fremont, CA
    SakeBombGarage.com - Performance Parts Manufacturing and Tuning
    SakeBomb Garage is proud to present Ohlins DFV for the Civic Type-R FK8
    Check them out for more detail here on the site!
    This setup has won the Hot Hatch challenge
    The Öhlins Road & Track suspension gives our customers a true racing experience, with their own cars, without losing comfort when commuting to work. Our unique Dual Flow Valve (DFV) technology allows you to quickly change the stiffness of the shock absorber. When arriving to the racetrack, just turn the golden knob clockwise on the damper to set it in race mode this action changes all four areas in the damper; low and high speed compression and rebound damping.
    With Öhlins Road & Track coil overs you will experience a car with blistering response times, improved bump absorption and a massive amount of grip to increase the safety when driving your car on the limit. The car will be easier to balance on the edge of what the tires can handle before losing grip. You will be much quicker on track. The DFV suspension prevents you from losing the racing line when hitting bumps or curbs. The DFV components within react quickly and keeps you in control of the car and in contact with the track. When driving to and from the track, just set the dampers in road mode for a more relaxed and comfortable drive, still with more grip and quicker response time than ever before.
    Pink_Group-110pm_Outside_Grapevine-BW1-6737-Dec0218-CaliPhoto__32637.1553017157.380.500.jpg
    jasonklor thanked this.
  2. TypeSiR
    TypeSiR Senior Member
    May 15, 2017
    678
    418
    Occupation:
    Car Driver
    1.5T Civic, CTR, MX5
    :thumbsup: Nice!
    Are they height adjustable like regular coilovers?
  3. OP
    SakeBomb Garage
    Dec 19, 2018
    Fremont, CA
    They're fully adjustable, you can go from OEM ride height to Nearly slammed. It's a full Coil over suspension Kit.
  4. jasonklor
    jasonklor unemployed CEO
    Apr 11, 2019
    303
    2001 Integra Type R #0700 | 2019 Civic Type R #25455
    So there’s only two settings to choose from, Road and Track, correct?
  5. OP
    SakeBomb Garage
    Dec 19, 2018
    Fremont, CA
    Ohlins dampers have a wide range of adjustability per corner. We can also work with you if you're interested in getting different spring rates!
    Ohlins Road & Track is the full name of the Ohlin DFV suspension.
