Official RallyArmor Mudflaps for the Type R
  1. ExileAeterna
    ExileAeterna Senior Member
    Nov 27, 2017
    85
    Occupation:
    US Naval Officer
    Pensacola, FL
    Dylan
    2018 Civic Type R
    Same problem here. Some screws on the back that are reused just spin. Look good though!
    02SilverSiHB thanked this.
  2. krees
    krees Senior Member
    Sep 17, 2017
    618
    517
    FL
    2018 Civic type r & 2017 Subaru WRX
    Yeah I had the same screw issues as all. Glad it wasn't just me and hoping we can get corrected hardware. I guess I'll contact them
    02SilverSiHB and EnjoyDriving thanked this.
  3. EnjoyDriving
    EnjoyDriving Senior Member
    Sep 3, 2018
    527
    125
    Minnesota
    2018 CW FK8
    Can we leave the washers off n would that work?
  4. krees
    krees Senior Member
    Sep 17, 2017
    618
    517
    FL
    Maybe? But the slotted holes has me a bit weary to attempt it without the washer. I'd probably be the guy to lose a flap. If I can't get remedy via rally armor I'll just go buy the correct hardware. Kinda disappointing though
  5. 02SilverSiHB
    02SilverSiHB Senior Member
    Jan 3, 2018
    1,968
    1,233
    Pasadena, MD
    2017 FK8
    I have a set on the way also. But yeah...150 for these and the screws aren't exactly right..kinda sucks
  6. Driveitlikeuboughtit
    Driveitlikeuboughtit Senior Member
    Jun 28, 2018
    820
    537
    2018 CW CTR
    Did anyone email RallyArmor and get a response?
  7. krees
    krees Senior Member
    Sep 17, 2017
    618
    517
    FL
    I submitted a ticket this morning. Planned to do it yesterday but got bogged down by work. Will keep this thread updated if I hear back.
  8. jimmer
    jimmer Member
    Dec 30, 2017
    56
    IL
    Jimmer
    CW CTR
    I did too, hopefully we can get others to do it as well as it may provide a quicker solution from RA
    krees and 02SilverSiHB thanked this.
  9. jimmer
    jimmer Member
    Dec 30, 2017
    56
    IL
    Jimmer
    CW CTR
    I wouldn't feel comfortable doing that
  10. jimmer
    jimmer Member
    Dec 30, 2017
    56
    IL
    Jimmer
    CW CTR
    here is the reply I received from R/A, I will attempt to do it again this weekend:
    Hi James,
    Thank you for your inquiry. Not to worry we can certainly assist in troubleshooting.
    In terms of the rear- the single OEM screw fastener is located close to the bumper skin and will install as before.
    This area incorporates a number of items so we would also advise checking the following items :
    • Part of the rear installation process requests a slight curvature be introduced on the rear bracket (Section i) . A bracket pushing towards the rear of the vehicle may create unnecessary space and push back on the area where the inner fastener is mounted to.
    • The riveted liner plate behind the bumper skin. There are two extended rivets holding a metal plate to the soft fabric liner. They can create a gap in this area if the rivets are not clearing the mounting point and would mimic the scenario you are describing.
    • OEM fastener mounting point. The liner rivets (and plate) can push back the OEM mounting point when reinstalling the components- just enough as to not allow you to initially catch. The sheet metal can be easily pushed forwards a few mm by hand, back into place if this has occurred as it is a simple L shape.
    We have attached an image of the inner rear Type R bumper area to help clarify what we are describing in this response ( direct link below)
    http://www.rallyarmor.com/images/rear_type_r_to_check.jpg
    We always advise hand threading the OEM screw first to ensure if is being installed into the center of the OEM insert, then applying some additional pressure as to allow the screw to catch the inner mounting area. Tightening the application with only until washer is seated.
    Regarding the front- While there are a number of OEM screws located in this area, there is a single mounting point on the vehicle that is behind the thick side skirt. (All other mounting points are directly behind the liner) would this be the single OEM screw you are referring to in your request?
    Specifically #2 in section A on the installation instructions included with your set found here:
    http://www.rallyarmor.com/honda_instructions/IMF47.pdf
    If so, would you be able to swap this with the 1SS screw we have provided with the OEM mounting screw and advise if this resolves your issue (#4 in Section E of the installation instructions)?
    Thanks very much,
    Team R/A
  11. 02SilverSiHB
    Jan 3, 2018
    1,968
    1,233
    Pasadena, MD
    2017 FK8
    Did you let them know that the 1SS screw is way to thick and the oem is too thin to swap, lmao.
    I installed mine and have the same issue
    But they look nice
  12. 02SilverSiHB
    Jan 3, 2018
    1,968
    1,233
    Pasadena, MD
    2017 FK8
    not using the washer was the only way to get it to stay...really dont want to leave it this way
  13. EnjoyDriving
    Sep 3, 2018
    527
    125
    Minnesota
    2018 CW FK8
    Only that one screw on driver side?
  14. 02SilverSiHB
    Jan 3, 2018
    1,968
    1,233
    Pasadena, MD
    2017 FK8
    mine went in fine on the driver side. this is the passenger side
  15. EnjoyDriving
    Sep 3, 2018
    527
    125
    Minnesota
    2018 CW FK8
    Have u tried taking the screw to hardware store to find one similar but longer? Or, anyone else has tried it yet?
