OEM Tires - Have you replaced due to wear?
  1. 2112
    2112 Senior Member
    Jan 31, 2017
    274
    298
    Cleveland, Ohio
    2017 Honda Civic Type R #00969 BLK, 2015 Nissan 370Z Roadster (BLK), 2019 Civic Si Modern Steel Metalic
    Hi there! I've owned my CTR since June of 2017 (#00969) and I have about 11,000 miles on her. Will be storing for the winter in a month or so and I was thinking when I get her out in spring I may have to look at replacing my OEM tires. I haven't tracked the car (why not???) so I only have normal wear for the 11K miles. Tires are suppose to last 10K, but they still look pretty good.
    Curious if others have replaced their OEM tires due to normal wear, at how many miles did you do this, and what did you replace the OEM tires with? I will probably go with the stock OEM tires for replacement, but wanted other opinions.
  2. GraphiteAZ
    GraphiteAZ Senior Member
    Sep 8, 2019
    118
    41
    Tucson, AZ
    Civic
    I have been planning this for a bit but I have awhile until I replace mine.
    I'm going with RE71r's on the OEM wheels.
  3. thatonedaveguy
    thatonedaveguy Senior Member
    Jan 3, 2018
    439
    624
    Texas, USA
    Dave
    19' CW Civic Type R #22487
    I replaced mine right at about 10k miles. They likely would have lasted another 200-300 tops.
    I replaced mine with Michelin Pilot Sport 4S. These tires have much higher performance than the OEM tires(Continental Sport Contact 6) in every measurable category and last 30,000 miles instead of 10k. No brainer.
    It would be a huge waste of money getting OEM tires again when much better longer lasting tires are around the same price.
    forrestbb, rgomez19, Foxington427 and 3 others thanked this.
  4. RedGiant217
    RedGiant217 Senior Member
    Jun 16, 2018
    597
    355
    Indiana
    2018 Honda Civic Type R, 2001 Honda Accord
    Mine lasted about 13k miles before I got a bubble in one sidewall. Went to 18in wheels with Firestone Firehawk Indy 500 tires.
  5. R-10552
    R-10552 Senior Member
    Feb 18, 2019
    151
    144
    NJ
    Russ
    2018 Honda Civic TypeR, 2003 Acura RSX TypeS, 2019 Civic Si (wife's)
    I haven't yet, but my buddy has a CTR with just under 10k and his tires are about gone. All depends on how you drive it.
  6. PwrOfDreams
    PwrOfDreams It ain't a Type R then it ain't a tight car
    Jun 25, 2017
    364
    216
    San Gabriel,CA (626)
    Jimmy
    Honda
    I had my tires last 22.5k miles before I had to replace them due to the fact that they are at the wear bars and traction was not good anymore. It was primarily used in daily driving traffic and highway cruising.
    Mature Banana thanked this.
  7. lid6662
    lid6662 Senior Member
    Apr 5, 2018
    152
    94
    Kansas city
    matthew
    2018 Civic Type R #11433 CBP
    I might have to next summer !! We shall see. Not sure what brand but thats not till next year haha
  8. CivilciviC
    CivilciviC Senior Member
    Oct 19, 2019
    131
    Western Canada
    2018 Civic Type R
    The OEM tires are terrible in every aspect. The fact they wear so incredibly fast, while providing average grip, boggles my mind. I don't know how Continental engineered such a bad tire. I also don't understand why it is so incredibly expensive. There's no justification for it.
    For best bang for your buck, the Bridgestone Potenza 71Rs are very hard to beat. If you have a bit more money at your disposal, the Michelin PS4S are a great buy, also.
    To those of you who want to get the most mileage out of a set of tires, buy the widest tire your rim will fit. Going up from a 245 to a 255 or 265 tire helps distribute the weight more, meaning a slightly bigger contact patch on the pavement- more weight distribution. This will help reduce overall tire wear. And for the record, yes, you can safely fit a 265 tire even on an 8.5" rim, without any issues.
    The only downside to going with a wider tire is slightly reduced fuel economy vs a narrower tire. But if you have lightweight rims, you can still come out ahead of the stock behemoth OEM wheels/tires.
    forrestbb, willskiGT and iCECORE thanked this.
  9. willskiGT
    willskiGT Senior Member
    Jul 1, 2019
    191
    104
    Occupation:
    Corp Strat/Bus Dev
    Atlanta
    2019 Civic Type R #26262
    My car has ~3950 miles and both of my fronts are at the wear bars in the center of the tire- the front right is also chunked. 2x20 minutes sessions on track just destroyed them.
    Rears have about 50% life remaining. My commute is about 8 miles roundtrip, 75% highway, 25% surface streets. Of my 4k miles, probably 1-1.5k of it has been aggressive driving (mountain runs/1 track day).
    Counterpoint - you can pick up a set of barely used OEM wheels and tires for like ~$800. That's a good bit cheaper than Michelin Pilot Sport 4S/Cup 2, plus you wind up with an extra set of wheels that have some value left. Effectively paying ~$400 for a new set of OEM tires. Agreed on Michelins being better, but they aren't $800 better ($400 vs. $1200).
    forrestbb thanked this.
  10. thatonedaveguy
    Jan 3, 2018
    439
    624
    Texas, USA
    Dave
    100% agree that downsizing on wheels is a solid choice.
  11. willskiGT
    Jul 1, 2019
    191
    104
    Occupation:
    Corp Strat/Bus Dev
    Atlanta
    Not downsizing - buying the OEM 20" wheels of someone who has. The OEM wheels are worth ~$100 each, so if you get a set of 4 OEM 20" wheels+tires with delivery miles on it for $800 (like I did), you are effectively paying $400 for a set of 4 OEM tires (normally $325/ea).
    Yes, you can also downsize, which is also not a bad idea, since 18"/19" tires are super cheap compared to 20".
    thatonedaveguy thanked this.
  12. zcEF
    zcEF Senior Member
    Aug 11, 2017
    112
    89
    Kitchener Ontario
    Chase
    2017 Civic Type R
    My tires lasted 20k km (~12.5k miles) with 2 track days. I wanted to use every last shred of tire before I swapped because I knew it was inevitably coming up. I dropped to 18s and bought some 265/35 9.5 Bridgestone Potenza RE-71Rs and holy, the OEMs are in no comparison to these (obviously). Couldn't be happier with my decision as with the rim and tire package it was only a couple hundred dollars more than buying brand new OEMs on the 20s. Sorry I'm not the best photographer.
    Do it.
    aldksgo thanked this.
  13. CivilciviC
    Oct 19, 2019
    131
    Western Canada
    2018 Civic Type R
    Counterpoint (lol)- you spend $800 on used wheels and tires (I haven't seen any great condition sets going for that cheap- probably only comes up once in a blue moon), and you still end up with tires with poor grip and terrible tread wear... And if you DD your car or track it, you won't get that much mileage out of them anyway.
    Yeah, you have a second set of OEM wheels which is a good thing, but, they'll just be taking garage space up until you sell them one day. And I don't know who is interested in these wheels for any car besides the CTR. And selling the wheels with no rubber becomes a bit harder- because the new owner needs to drop big bucks for 20 inch tires on wheels that most nobody really even wants.
  14. willskiGT
    Jul 1, 2019
    191
    104
    Occupation:
    Corp Strat/Bus Dev
    Atlanta
    Maybe not in Canada, but I easily found a set with <100 miles on them for $800. They are a dime a dozen down here.
    My commute is super short (8 miles round trip), so 10k miles of commuting is literally 5 years of tire life for me. I don't find the grip to be bad - they are 240TW tires, so they do grip pretty well. They are just noisy and wear ultra fast.
    But yeah, good point that the wheels are a tough sell (hence the super cheap $100 price point). I have a huge storage shed and a 1400 square foot basement, so storage space at least isn't a concern.
  15. Ducky
    Ducky juiceboxes
    Jul 17, 2019
    218
    132
    Occupation:
    software goon
    Austin, TX
    Brandon
    '07 LBP S2000, '19 CW CTR
    The OEM wheels are going to be expensive as fuck in 10 years based on how disposable everyone treats them today.
    UberCivic and Coldpizza thanked this.
