Noob Question regarding shift timing
  1. privilegejunkie
    Sep 8, 2019
    Kansas City, Missouri
    James
    2019 Honda Civic Type R
    Hey all. Some background: I recently purchased a Civic Type R which is my first manual car. I borrowed a 1999 ford escort for a few months to learn on, but it was worn to hell and back, meaning the clutch on it was very janky and hard to feel for.
    My question is in regards to smoothly shifting gears in relation to acceleration. I notice that if I want a perfectly smooth shift with no lurching or jolting, I have to shift somewhat slowly in order to give the engine enough time for the revs to go down. I can do this easily and consistently and it leads to a very smooth shifting experience. However, if I'm really wanting to accelerate quickly, I dump the clutch quicker and press the throttle a bit quicker so that it catches in a more abrupt manner. This gives me the result I want (quick acceleration) but it seems rough.
    Is it normal and/or unavoidable to have small jolts between shifts when accelerating quickly?
    MutatedMango thanked this.
  2. Deadly Nancy
    Deadly Nancy Member
    Apr 5, 2019
    26
    Occupation:
    Software Engineer
    Washington
    2013 CR-Z, 2019 Civic Type R
    Quite frankly, yes. As with all things, practice makes perfect. The more you practice and make tiny subconscious adjustments, the smoother all shifting will become. Eventually your body will be prepared for the jolt and will counteract it accordingly. You wont even notice it anymore but your passengers will.
    Yes, learning to drive a manual will wear out your clutch faster than someone who knows what they are doing from the get go, but i wouldnt worry too much about it.
    Naruske and privilegejunkie thanked this.
  3. darrvao777
    darrvao777 Senior Member
    May 18, 2019
    120
    61
    Partenope
    '19 CW CTR, '18 G550
    It is normal to have small jolts between shifts when accelerating quickly.
    That being said, if I'm trying to accelerate quickly, I'm usually not shifting. I'm running up the RPMs until redline.
    I do find shifting quickly, getting back on the gas, and smoothly letting out the clutch helps with jolts between shifts.
  4. OP
    privilegejunkie
    Sep 8, 2019
    James
    Oh absolutely. If I'm trying to accelerate quickly I'll always go to the redline. The longer between shifting the better!
  5. Lust
    Lust Senior Member
    Apr 17, 2018
    326
    219
    Bay Area
    Michael
    2019 Champ White Type R
    #5 Lust, Sep 17, 2019
    It's because this car still has some slight rev hang. It can be tricky to shift quick but with practice it's easy. Practice getting really good at shifting without any gas. This will help you build muscle memory of getting to the engagement point quickly.
    As I'm almost off of the gas to shift, I will quickly clutch in and quickly clutch out right before the engagement point. My leg will then "hitch" or slow down at the bite point to smooth out the engagement. Once I feel the clutch is almost fully engaged, I'll gradually apply throttle.
    Some mistakes I made as a novice manual transmission driver
    -Clutching in with too much throttle applied
    -Clutching out too fast past the engagement / bite point
    -Applying throttle before the clutch is engaged properly
    Jay19Si and privilegejunkie thanked this.
  6. MutatedMango
    MutatedMango Senior Member
    Mar 24, 2019
    292
    110
    Occupation:
    Student
    Philadelphia
    '19 Civic Si coupe
    What you're describing is something called rev hang which plagues the 10th gen civics. To get rid of it you'd have to go aftermarket like Ktuner or something
  7. Rowwwel_808
    Rowwwel_808 Member
    Feb 26, 2019
    Maui, Hawaii
    Roel
    2018 Honda Civic Type R
    Yup. It’s the rev hang that ruins smooth shifting. We should be glad that the rev hang isn’t as bad as it is in the Si’s. Even my 9th gen Si had horrendous rev hang. Is really annoying. Shitty that you have to tune to get rid of it completely. I’ve just learned to live with it and adjust my driving style accordingly. I personally don’t wanna tune until I’m out of warranty. Nothing you can do about it, really.
    MutatedMango and privilegejunkie thanked this.
