No drill hitch
Sethvon
Seth
Charlotte, NC
2018 Honda CIvic Hatchback Ex
Hey everyone,
I have an '18 civic hatchback ex. I wanna install a hitch myself. I done some reserch and it seems pretty simple. All of the videos i've seen require drilling additional holes in the frame. Does anyone know of a hitch that doesnt require any drilling at all. And if so, is there a difference in quality, strength, and reliability?
All I wanna do is throw a bike rack on the back. Maybe haul something with a little more weight.
I appreciate any responses.
Thanks
Sethvon
Sethvon
Seth
Charlotte, NC
Thanks for the quick reply!
Did you have to do any drilling to the frame? I keep seeing people say they had to remove some material. But not clear on what they mean. I tried to open the instructions but the page won't load. Does anyone know of a install video?
Sethvon
Sethvon
Seth
Charlotte, NC
I installed the same hitch (Draw-Tite) and plug and play wire harness, pretty easy to install. I have a small utility trailer.
Thanks fitter_here!
Did you have to do any drilling or cutting of the frame?
I'm trying to find a solution without altering the frame
fitter_here
Ste-Anne-des-Plaines, Quebec, Canada
Civic LX 2016 Sedan
Thanks fitter_here!
No, very easy to install. Just remove the bumper cover et the bumper, straight forward. Be careful when removing the bumper cover.
You have the instructions on ETRAILER.COM for the DRAW-TITE hitch.
fitter_here
Civic LX 2016 Sedan
The only thing that is a bit longer is if you want to install the plug and play wire harness (T connectors) you have to pass a wire to connect to the battery. But this much better than splicing the wires because the wires on cars nowadays are very small.
Sethvon
Sethvon
Seth
Charlotte, NC
For some reason I can't open the instructions from Etrailer.com. I found install instructions from Carid.com And one of the steps is to remove some metal on the bumper. They don't explain why you need to cut out the metal.
Then they show a picture of the hitch installed and the metal on the bumper is not cut out.
Any thoughts on that?
It seems like all I have to do is take the bumper cover and bumper off. Then bolt on the hitch and bumper. Then put the bumper cover back on.
Does the bumper stick out farther from the frame because the hitch is now between the frame and the bumper, and that is causing the bumper to now hit the bumper cover?
Did you run into that issue?
Also, Thanks for all your help
fitter_here
Civic LX 2016 Sedan
You have to cut the black plastic, 2"3/4 X 4"
A picture is worth a thousand words.
fitter_here
Civic LX 2016 Sedan
Here's the instructions in PDF for the Draw-Tite
Sethvon
Sethvon
Seth
Charlotte, NC
You also have to trim the bumper for facia clearance as per figure 2. Easy to do.
For this did you have to cut that part out? or just grind it down? How did you complete this part of the install?
