Night Fury
  1. OP
    Night Fury
    Night Fury Senior Member
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
    Undercover mod for Night Fury.
    2 seconds install, 3 hp gain!
    wassen thanked this.
  2. OP
    Night Fury
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
    Miscellaneous.
    I was finally able to level this sucker, it is not hard at all.
    Material used, was a bit of foaming material from the lightweight battery.
  3. OP
    Night Fury
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
    I did really like to do this one. Couldn’t stop thinking about to add one more layer in top of the downpipe, I felt it was stil naked and susbceptible to spread heat.
    It came out really, small trim, reusing original bolts and cover.
    Pretty :love:
  4. CincyTypeR
    CincyTypeR Senior Member
    Jun 15, 2017
    1,013
    572
    2017 Type R #0426. 2014 Accord Coupe V6
    Any feedback to provide on your lightweight battery after a few months?
    Been debating on changing to a lightweight battery but unsure about which product I should pick. Also if I really should since I don't daily drive my Type R.
    .grimace and Night Fury thanked this.
  5. ipeefreely
    ipeefreely Senior Member
    Jun 5, 2018
    376
    476
    Bay Area
    Will
    2017 Ford Raptor / 2017 Acura NSX / 2019 CTR
    I purchased the shorai battery due to its weight but ended up selling mine because I didn't drive my car enough. From my understanding, if you don't move your car at least every 5 days, you're probably better off just sticking with the stock battery.
  6. OP
    Night Fury
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
    Hi there.
    I do recommend Shorei battery, definitely it helps with unwanted weight on the car. Another one I have always like is Braille battery, I already had two of them, plus the customer service was very good when they replaced for me under warranty.
    Purchase, install & Maintenance has not been an issue for me.
    I just came back from road trip in Miami, Florida with that battery and NO ISSUES. I live in Chicago.
    Haven’t got any issues either: in the snow, hot weather A/C ON & traffic jams.
    They last about: two to three years and with a good Maintenance ( to turn it often) they don’t bring you problems. Just make sure to register your warranty.
    I hope this helps! :thumbsup:
    He is right, for a lightweight battery, you have to use it regularly, 4 days without crank and gradually the battery will under-perform. This will or should dictate to get one.
  7. ipeefreely
    Jun 5, 2018
    376
    476
    Bay Area
    Will
    btw. I was wondering how you were mounting your battery? I installed the shorai in mine for a few days and even utilizing all the included foam, it was not seated that well.
  8. OP
    Night Fury
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
    I just used the foam only to correct the height – I didn’t surround the battery , this aligns exactly with the battery holder metal strap with same height as the OEM battery. So far the foam is good & no play yet.
  9. EnjoyDriving
    EnjoyDriving Senior Member
    Sep 3, 2018
    513
    124
    Minnesota
    2018 CW FK8
    hey Fury, since you took off the scoop b4, do you see any possibility for water getting into spark plug area thru the big center hole n other smaller holes?? if so, should we plug those holes? i m getting concerned about corrosion ppl found in that area
  10. OP
    Night Fury
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
    You just read my mind. After watched the video done by FlyingGato, I realized those wholes most likely let water pass to the top of the engine cover, agree. I am considering source flat rubber plugs for them, then later check after a test car wash, if the water residue still going in the same route.
    EnjoyDriving thanked this.
  11. EnjoyDriving
    Sep 3, 2018
    513
    124
    Minnesota
    2018 CW FK8
    Found these on amazon, would they work?
    Wonder if they can take the heat though...
    https://www.amazon.com/CAPLUGS-Assorted-Flush-Mount-Furniture/dp/B077R25QQV
  12. OP
    Night Fury
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
  13. OP
    Night Fury
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
    When you bored with the weather.
    davemarco thanked this.
  14. OP
    Night Fury
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
    Finally I’ve been able to take a moment and share this story..
    NIGHT FURY DOES MIAMI!!
    Preparation:
    For those who track or road trip their CTR’s.
    I used TRACK ARMOUR TAPE, instead of the regular Home Depot masking painter’s tape( green or Blu). And I have found a black masking tape that matches with the color of my car. This mostly for the black pearl owners. :D
    Tips: to apply, wash the car and put any type of wax that you want, when apply the tape, make sure is room temp.
    jcp227 thanked this.
  15. OP
    Night Fury
    Jun 13, 2017
    945
    656
    Chicago
    Black Type R
    jcp227 and .grimace thanked this.
