BobbyA
- Bobby
- Nov 19, 2018
- 14
- 77
- 59
- Fredericksburg, VA
- 2018 Civic Si Coupe (PRL Stage 1, Hondata FlashPro, PRL Flex Fuel e85, HardRace Rear Mount, Megan Racing Strut Bar) Wish List: PRL Catted Downpipe, Eibach Pro Springs Kit, Seibon Carbon Fiber Hood & Trunk.
Installed the new PRL e85 Flex Fuel Kit in my 2018 Civic Si today. WOW! What a difference it makes, it's not just tons of extra pull, but the motor has a whole new growl to it as well. I really like this kit, the fit and finish is polished and is done in such a way that if you want to remove it, will be fairly simple to return to factory settings. I think Hondata posted 65hp gain from using e85 with their tune, simply incredible performance for the money. Also, it's CLEAN Burning fuel, has a very sharp reduction in CO2 emissions, almost 100% reduction. For now, I'm using the straight e85 at the pump, no further dilution. Here a couple notes if it helps anyone:
1) Takes about 30-35 minutes, 10 of which is removing and replacing the under-body aluminum bonnet.
2) The hardest part imho, is the lower Coolant Sensor on the side of the Radiator, which is accessed under the vehicle. I'm right handed so fyi, to get this sensor unplugged, the clip is on the very bottom, you'll need to push up on the clip and contort your LEFT hand and body in such a way you can push it off and then plug into the PRL line. Get a 400 lumens flashlight so you can see. It's a very tight spot and dark in there.
3) I then used my right, one hand to connect both plugs - the Honda Factory plug into the PRL line or plug (there is no space in there for 2 hands, so this will take some effort.)
4) Pretty much everything else is easy and straightforward to install.
5) I'm using the Hondata e85 Ethanol Tune. I believe the calibration indicates it is +6psi. About the only setting I changed or "opted in" for was the aggressive throttle response. See my pic with the screen shot.
6) Just curious if anyone else is using the Hondata Ethanol tune and did you make any other changes? If YES, can you please screen shot them and post up? Thanks!!!
