New HardRace Front Lower Camber Adjusters
GeezR
Cincinnati
Honda Type R, Caterham, VW Touareg, Chevy Volt
A bit confused by this thread. Did anyone run these Hardrace front lower camber adjusters with the stock suspension set up? If so, what was the additional negative camber gain? And was there an increase in torque steer? Most posters appear to be combining these front lower camber adjusters with springs that differ than stock (shorter, skinnier, etc). Is that required to gain any advantage withe these particular camber adjusters? I'd like to keep my suspension as close to stock as possible. But I am experiencing significant outer edge tire wear on my R71R's at the track. So I'd like to be able to dial in additional camber, esp in front.
alpinefd
Walnut
2019 Civic Type-R
using the lower ball joint to adjuster camber (making the track wider, moving the ball joint outwards), reduces torque steer !
this is perfect for lower offset wheels (like +35), so you can get the benefit of wider track width.
Very exciting product !
using front top camber plate to increase negative camber (tilt the top of the damper inward) does not help with torque steer (honda separated the 2 axis in the fk8 civic type-r)
more info is here to understand how the honda design works
https://global.honda/innovation/technology/automobile/Dual-axis-strut-suspension-picturebook.html
19typeRblk
Jack
South Carolina
1989 Porsche 944 turbo S, 1978 Porsche 911SC, 2014 Toyota Tundra
I'm taking my 2019 CTR to the track for the first time to do HPDE at Roebling in Feb. So went to my local shop to have the shock tower pins removed and dial in 1.7- chamber. The ailment guy came out to the waiting room and told me factory was already -1.5 do you want an additional -1.5??? So -3 I is pretty aggresive for occasional track and mostly street use. So we agreed on -2 chamber. What suprized me was the toe was out front and back. I've never hit a pothole or curb and generally don't beat on it and consider myself a smooth driver ( smooth=fast)
The car only has 3,400 miles. Had the shop set the toe to factory spec.
All I can say what a difference!! The car feels so much more on center, turn in is more stable and it just tracks so much better and enjoyable to drive if that's possible. If anyone is interested I can post alienment print out
hpbyhermann
Hermann
Edgewater Maryland
2019 Championship white Type R #25133, 09' Civic SI sedan, black 2013 Boss 302 Laguna Seca, 1993 Mustang Cobra, 2004 Mustang Cobra
Absolutely post the alignment sheet! I'm getting ready to do mine soon.
.grimace
Byron
Reno, NV
2021 Honda CTR, 2022 Range Rover , 1990 CRX SI
Your tires were super low on air too. Do you live somewhere warm in summer and cold in winter?
19typeRblk
Jack
South Carolina
Yes I live in SC so the night before I went to the shop the temp dropped 22 degrees!! But no TMP light came on......strange. The shop did tell me my tires where low and that they always put correct tire pressure in before checking alienment. I think I believe them
But to restate, after the alienment the car has never felt this good, even when I picked the car up new from the dealership. I'd be surprised that by adding -.5 chamber would make such a difference. I'm thinking the toe setting also help immensely
.grimace
Byron
Reno, NV
Yea I pulled those pins then had my buddy align it. Definitely needed it.
19typeRblk
Jack
South Carolina
So was your toe setting out like mine? And did you change negitive chamber setting?
If so is your car tracking better?
.grimace
Byron
Reno, NV
It’s been so long I don’t remember. I’ve since then lowered it and added even more negative camber and wider tires so I couldn’t tell you
19typeRblk
Jack
South Carolina
Wow lowered and wider tires! I'm not even in the same ballpark with my wimpy stock CTR : )
.grimace
Byron
Reno, NV
hah nah all just basic stuff! They’re so fun in any form
19typeRblk
Jack
South Carolina
I've owned everything from E30 M3 BMW to 993 Turbo and I love my CTR just as much and absolutely love driving it! Can't wait to see how it is on the track. Being front wheel drive, it should be interesting as front wheel cars are prone to understeer. Hopefully Honda has dialed most of that out with the CTR I'm quite sure they have as it went around the ring in 7:43
.grimace
Byron
Reno, NV
Ive owned and tracked a wide variety of cars from corvettes to Miatas or FD Rx7 and have to say this is probably my favorite car. You’ll barely notice it’s FWD, so composed and fun to drive.
