New audio setup with DSP
  1. makanouchi
    makanouchi Senior Member
    Oct 31, 2017
    71
    78
    Austin,TX
    Lac
    2017 Civic Type R
    #1 makanouchi, Jan 15, 2020
    Ok, first round of upgrades done 1 year ago with replacement front speakers including center. RF shallow mount 8 in stock enclosure powered by RD 300 watt amp. Sound deadening where possible. I wanted to keep things simple but the mod bug got me again.
    Read every single forum post about audio upgrades and sound correction. Here's my solution:
    Front: Hertz MPK 165.3
    No center speaker
    Rear, left stock powered by factory amp
    Sub: JL 8w3v3 4ohm, 1 inch ring added to factory enclosure, dynomat inside and outside of factory box, polyfill inside the box. Still working on a grill solution to hide the holes from the factory grill mounts.
    On to the interesting bit:
    Amp/dsp: audio control D-4.800. 125 x 4 with built in dsp. The unit has 6 channel input, I fed in front doors to front imput, front tweeter to high input, center to rear left input and sub to rear right input. All inputs are summed to give full range plus nav voice. Attached are the input and output curves. Accu bass is added around 25 volume. Sound is Crystal clear with 0 distortion. Time aligned so the sound stage is in the dash...without center speaker.
    Hit me up if you have any questions. Thanks for everyone on the forum posting their setups.
  2. OP
    makanouchi
    Oct 31, 2017
    71
    78
    Austin,TX
    Lac
    2017 Civic Type R
    Screenshot of dsp. Usb cable ran from trunk I to center console. Tuning from drivers seat is a beautiful thing.
    calonzo thanked this.
  3. calonzo
    calonzo Senior Member
    Feb 13, 2017
    559
    117
    New Haven, CT
    2016 Honda Civic Touring, 2007 Honda Civic Hybrid
    Wow! Thanks for all the details. I like that the AMP/DSP are in one unit.
  4. ManfromRI
    ManfromRI Senior Member
    Jul 14, 2018
    77
    34
    Occupation:
    Welder/Sheetmetal worker
    RI
    17' CW Civic Type R
    Nice!! I have that exact DSP. I'm looking to install it in the spring along with my Focal components in my R. I'm glad it works well with your setup.
    Did you have to sum all 3 inputs to get a clean flattened out signal?? Did you have to tweak it alot to get it where it needs to be??
  5. OP
    makanouchi
    Oct 31, 2017
    71
    78
    Austin,TX
    Lac
    2017 Civic Type R
    The front speakers have all input channels summed. Take a look at the 4th image showing the output for the front speakers. With the DSP, it's actually really to get a flat output. Play pink noise and run the auto eq process a few times, this gets really close. The sub is summing factory door speakers and factory sub, this give me the full low range. I still need to make some minor adjustments to suit my ears but it sounds great already. Crossover currently set at 80 hertz between sub and kids.
  6. ManfromRI
    Jul 14, 2018
    77
    34
    Occupation:
    RI
    17' CW Civic Type R
    Nice. Another question. Which harness did you tap into?? The post amp one??
  7. OP
    makanouchi
    Oct 31, 2017
    71
    78
    Austin,TX
    Lac
    2017 Civic Type R
    Yes, tapped at the amp in passenger kick panel.
  8. OP
    makanouchi
    Oct 31, 2017
    71
    78
    Austin,TX
    Lac
    2017 Civic Type R
    Some updates, got my hands on some Hertz Mille MLK Legend 1650.3 components. These speakers are a work of art. Installed, disconnected all rear speakers, set crossover to 70 Hertz. Bass is so good from the components, you almost don't need a sub.
  9. ManfromRI
    Jul 14, 2018
    77
    34
    Occupation:
    RI
    17' CW Civic Type R
    This is the correct plug right??
    Those speakers look great!!! Are you running them active??
  10. OP
    makanouchi
    Oct 31, 2017
    71
    78
    Austin,TX
    Lac
    2017 Civic Type R
    Correct, wiring diagram found here:
    https://www.civicx.com/threads/civic-si-amp-location-and-wiring-diagram.42290/
    I initially used the passive crossover but just switched to active yesterday. Need to add back in the sub amp, using the 4 channels for mids and teeeters.
    ManfromRI thanked this.
  11. ManfromRI
    Jul 14, 2018
    77
    34
    Occupation:
    RI
    17' CW Civic Type R
    Great! Thanks for the link. I'd be curious to see/hear the difference (if any) by making the switch from passive to active on an RTA.
    I mean I know by using the supplied x-over you are giving the exact frequency's that the designer intended them to receive. But as you know, every car is different and I'm sure there is a little wiggle room to fine-tune the speakers to your specific application by running active.
  12. OP
    makanouchi
    Oct 31, 2017
    71
    78
    Austin,TX
    Lac
    2017 Civic Type R
    Got some wire loom from Amazon and cleaned up the power wire in the engine bay. Fuse is screwed to existing wire management bracket. Looks almost factory now.
