Maplestory
What do you guys think about Ark new exhaust for our si sedans?
Tempted to get this or the hks.
I also have the resonator delete with the Vibrant 1040 muffler and suffer from a horrible tuning fork type of noise in high rpm's. I can't recommend this setup since it has created this same issue for several members. The common denominator is the Vibrant 1040 muffler.Not for nothing, but my custom setup sounds just as good, IMO. This video is with a resonator delete and a Vibrant 1040 muffler. Everything welded in high grade stainless. Since this video, I’ve added a catted DP/FP and it sounds even better.
I honestly can say that I haven't noticed this. I had mine welded by a stainless guy. Maybe I have a different bend? I do get a weird howling when I really get on it, but I can hear that below 4k rpms also. I thought it was the tires, but put in wider summer tires and it does the same thing. I need to try to get a recording of it.I also have the resonator delete with the Vibrant 1040 muffler and suffer from a horrible tuning fork type of noise in high rpm's. I can't recommend this setup since it has created this same issue for several members. The common denominator is the Vibrant 1040 muffler.
https://www.civicx.com/threads/loud-whistle-whine-over-4k-rpms.35831/
That's basically any exhaust for these cars, no?Personally though i could not justify a grand just for better sound with little to no performance gains.
Ha ha I would stay away from a custom exhaust, OEM is the best, IMO. I said this before, most people go chasing after sound, regret it but can't go back to the OEM because they got rid of it or it's too expensive or to much work to reinstall.@amirza786 I'm current sitting at 34k miles. Should I blow a grand on this or the extended Hondacare Warranty?
That's probably sound advice, but these 1.5 turbos are untested. That's the only reason I'm considering the warranty.Ha ha I would stay away from a custom exhaust, OEM is the best, IMO. I said this before, most people go chasing after sound, regret it but can't go back to the OEM because they got rid of it or it's too expensive or to much work to reinstall.
I also say if you own a Toyota, Lexus or Honda, an extended warranty is a waste of money. A study by consumer reports showed that by the time you needed it, you are already at 150k, way past the extended warranty period. Now if you own a BMW, VW, Ford or GM, you will for sure need it and use it.
Spend your money on a quality performance Intercooler
