BlueLdr
- Eric
- Nov 11, 2018
- 4
- 90
- 110
- Maryland
- 2018 Civic EX Sedan (ABM)
- Vehicle Showcase
I'm planning on getting new wheels for my EX Sedan in the coming months, and I've been toiling over what tires and wheel width to go with. For wheels, I'm upgrading from the 16x7+45 alloys, and I've narrowed my choices down to the Enkei TS9 (18x8+35), Motegi MR140 (18x8.5+35), Flow One F3 (18x8+40), and Avid.1 AV-27 (18x8.5+35). For tires, I'm upgrading the stock 215/55R16s to 225 or 235/45R18, and I'm deciding between the Pirelli Cinturato P7 All Season Plus and the Continental PureContact LS (and maybe the Michelin Premier A/S). I have several concerns about how my driving experience will change from what it is now.
I'd also like to know if I need to worry about rubbing issues if/when I decide to lower my car down the road (the drop would be less than an inch). Other advice on which wheels/tires to go with is also much appreciated.
Thanks!
1. The most important factor to me is road noise. Currently, it's not usually very noticeable, but it can get loud at times. I'm aware that wider tires generally create more road noise, but I don't know if going from the mediocre stock Firestones to a GT tire won't mitigate or even overcome the effects of the wider tire. If it does compensate for the tire width, I'll probably end up going with the PureContact or Premier, since they have much better handling ratings then the P7. On the flip side, if the wider tires are going to be louder no matter what, I don't see any option besides the P7s, since they seem to be by far the quietest tire in the category.
2. The second concern I have is about wet road handling. Wider tires typically do worse in wet conditions, but again, I don't know how much worse (or better) they'll be than the stock Firestone FT140s, which have seen very little praise on these forums. The main thing stopping me from going with the P7s is their considerable shortcomings when it comes to wet handling. If they're still better than the current tires, then I wouldn't consider it an issue, since I haven't had any problems with these tires so far.
3. Next is fuel economy. Unfortunately, the stock 16x7s don't have a weight listed in the sticky at the top of the Wheels/Tires forum, so it's hard to compare weights (if anyone knows the weight that'd be greatly appreciated). I was getting 35-37MPG in the fall, and it's dropped to 33ish during the winter, mostly highway driving, and a bit spirited at times. With wider/heavier wheels, it seems there's no avoiding some decrease in MPG, but I'd like to limit that drop to 2-3mpg. Is that a reasonable expectation? What difference in MPG would you expect between an 18x8 with 225/45 and an 18x8.5 with 235/45 (due to both weight and tire width)?
4. Whenever I read about speedo error from changing wheel size, people seem to talk about it like it's something you just have to live with. But is there any reason I can't just go to the dealer or a shop (or buy the calibration device) and have it re-calibrated?
5. Finally, I'm wondering about tire stretch. I'd like to go with 225/45 to help address the above factors, but if I were to put those on an 8.5" wheel, would the stretch be completely safe, and how would it effect noise and fuel economy?
Thanks!
