CyberCT
- Aug 20, 2018
- 10
- 159
- 53
- Nazareth PA
- 2018 Civic SI Coupe
Before jumping into the SI, I owned an RSX for 9 years. Stock camber values were -0.5 front, -1.5 rears. Even with suspension, cassis bracing, and upgraded rear swaybar, it still understeered. I had an alignment done that swapped front & rear camber values and this was the final suspension related piece that was needed. The RSX handled amazingly well. It was perfect.
While the stock SI handles impressively good it does understeer. I'm upgrading my rear sway bar and chassis bracing and want to do the same camber swap. However, I understand the suspension setup is different from the RSX and don't know how much value it will add. I'd have to buy camber arms (rear) & camber ball joints (front).
From various alignment before/after sheets posted on this forum, it seems the SI and other trims (except TypeR which has different front suspension & -1.5 fronts) are close to -0.5 front, -1.5 rears in stock form.
I also read one user that had -1.0 camber up front had to keep his car straight on the highway because it wanted to wander. I didn't have that issue on the RSX and I wonder why.
Who has done actual camber adjustments on their Civic, what camber settings did you end up with, and please provide input as to understeer/oversteer/ highway wandering, etc.
