Need help with Ktuner
  1. aydingokce
    aydingokce Member
    Jun 22, 2017
    Turkey
    2017 Honda Civic HB 1.5 Sport CVT
    Hello all,
    I am now on the progress of a tune with Vittuned and I purchased a Ktuner V2 for this purpose. On the way of the calibration progress, Vittuned informed me about that I am not flashing the calibrations they've sent to me properly since we really do not see a boost any more than 7psi.
    What I do is, I use the open tune option on Ktuner software, select the calibration file they sent to me and then use the upload base code option to upload the calibration onto the unit, then I go to the car and flash it. Can you please help me about what I am doing wrong? Thank you very much in advance.
  2. ddood
    ddood Senior Member
    Feb 17, 2017
    242
    118
    Australia
    Honda Civic 2016 VTI-LX
    What are you doing to flash the calibration on the car? If you elaborate, somebody should be able to help.
  3. OP
    aydingokce
    aydingokce Member
    Jun 22, 2017
    Turkey
    Thank you very much for your reply. I made two unlisted short youtube vids for that.
    I am pretty sure that I am doing something wrong in the process of uploading the calibration onto the device. Because, I am flashing the factory tune onto the ECU exactly the same way as I do in the 2nd video and it just works fine. However, I cannot get those VitTuned calibrations right.
    ChinStrap thanked this.
  4. ddood
    ddood Senior Member
    Feb 17, 2017
    242
    118
    Australia
    Can you check in KTuner under Tools > Reflash Info what your ECU software number is? Then create a new tune using one of the base maps by choosing the same software number, flash this tune and see if it works . If not, you probably need to contact JR at KTuner for help.
    I assume you are keying the car off and on after pausing appropriately (relay will click) after the flashing .
  5. OP
    aydingokce
    aydingokce Member
    Jun 22, 2017
    Turkey
    I do the key off and on as instructed by the device. I did not really get what you are trying to say, but if you are mentioning about flashing one of the ready tunes which come with the unit, I did that and it just worked fine.
    Do you think that the way I flash the pre-formed calibrations (by someone else) into the car is correct?
  6. 360glitch
    360glitch Moderator
    3,615
    3,503
    2017 Civic Si Sedan
    Everything looks good to me. If you haven't already, reach out to Ktuner directly at [email protected]
  7. OP
    aydingokce
    aydingokce Member
    Jun 22, 2017
    Turkey
    Problem is still not resolved. Now, I am asking for help explicitly: Is there anybody, who already has a Vittuned custom tune for his Civic 1.5 T CVT and is willing to help me via DM?
  8. dc2turbo
    dc2turbo Senior Member
    Jan 27, 2016
    2,913
    2,005
    usa
    civic,teg
    this is something you have to talk to vit or ktuner directly since its a custom calibration
    does one of the stage basemap work fine?
  9. KTuner
    KTuner Senior Member
    Jul 10, 2017
    1,758
    2,253
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    He's right.
    And if you have the same issue on a KTuner tune include a datalog and a copy of the tune file. For any custom tune you'll need to work with the tuner directly.
  10. OP
    aydingokce
    aydingokce Member
    Jun 22, 2017
    Turkey
    Thank you for your replies. Unfortunately, he refuses to help and insists that I cannot flash the calibrations and / or cannot do a WOT run properly. All I am trying to do is, before an initiating a forum war against him, to make sure that it is not my fault.
  11. ddood
    ddood Senior Member
    Feb 17, 2017
    242
    118
    Australia
    Are you doing the WOT runs correctly? It means throttle to the floor and keep it there until you reach the desired speed. You obviously can't do this if the road is busy etc so you will have to take that into account.
    There are loads of members here who have Vit custom tunes, including myself. Haven't seen anybody else with the same issue.
  12. OP
    aydingokce
    aydingokce Member
    Jun 22, 2017
    Turkey
    Of course I am doing it. There is no problem when using a ready Ktuner calibration, I get the full boost but not when custom Vittuned calibration.
  13. dallasjhawk
    dallasjhawk Senior Member
    Oct 3, 2016
    3,622
    3,528
    Arlington, TX
    2016 Civic EX-T, 2004 Acura TSX
    your datalogs tell a story, if you aren't WOT the whole time it will show fluctuations in the throttle position sensor. he isn't telling you something as a lie. As for full boost, my first calibrations with him the boost was turned down to get some baseline WOT pulls in. Each successive calibration the boost picked up more an more.
  14. 360glitch
    360glitch Moderator
    3,615
    3,503
    2017 Civic Si Sedan
    You can post your logs in a zip file here if you'd like them reviewed.
