Myx
- Mar 6, 2016
- 79
- 2,166
- 2,042
- Delaware
- 2018 Honda Civic EX (Hatchback/CVT)
- Vehicle Showcase
Was sitting back thinking about ideas on intakes and this idea came to mind. I call it the 'Myxal WTF Intake'. When you see the pic below, you may say 'WTF'. The air filter is in reverse of what we typically would assume an intake should be.
It utilizes the driver's side fog light with the Honda Sensing hole as the air intake portion. You install a funnel that captures the air at this location and directs the air up to maf sensor location. However, on the tube/pipe/device that you have leading up to that location, you install the air filter itself. The surround the air filter with a large open box of sorts that have the maf sensor connected to it.
This serves a few purposes:
1) Easy air filter cleaning.
2) Big open box area for the turbo to have immediate air pull from off idle vs a tube that'd empty out quicker.
3) Big open box area for incoming air to build up at when letting off the throttle. The ram-air like incoming air at the foglight should help with fuel economy since getting back on the throttle will have some extra air available. **In Theory**
4) If paranoid, can make very tiny hole at top of box in case of driving into water that'd cover the foglight area.
I was concerned about turbulence at the maf sensor since a filter isn't attached (or maf sensor screen of sorts) to 'straighten' out the air flow. However, intakes like the PRL comes off a bend and go straight into the maf sensor without issue. Even with a larger maf sensor (PRL Race Maf), turbulence doesn't seem to be an issue, with nothing in front of it to slow down/straighten out the air.
Just sharing some thoughts. I've done this on other forums and usually make the silly intakes to test at a dragstrip. If it seems easy to throw together, will post.
Feel free to share your thoughts. I welcome compliments as well a humiliation. Will be interesting to test though.
