importrx7
- Scort
- May 12, 2019
- 5
- 14
- 2
- Columbus, OH
- White 19 Civic Si coupe
Where can I get that maf sensor housing?
From this ThreadFor understanding purposes only:
FACTS.................
Note: In a FI vehicle, the air entering the combustion is after the IC. So, adding an aftermarket intake (claiming to provide more "cold air") is a moot subject. That colder air is being compressed and heated up by the compressor, then through the IC to be cooled - before being added to the combustion. A higher efficiency drop-in filter would function just the same (especially on a limited turbo). All that is needed is to have increased velocity.
After putting on my map intake my iat1 gets hotter than stock box but iat2 is the same or even lower(10-20 above ambient). I also have a PRL Intercooler. From what I’ve read around on other forums etc the benefit of colder pre turbo air is that colder denser air is better for the turbo to compress, the turbocharger has to work less compared to compressing hotter air. I’m not sure how accurate that is on this scale of temp difference. I did a lot of research on it before getting the map intake cause I was worried about losing power with higher iat1. Also from drob instagram page he recently tuned a full MAPerformance bolt on car that made basically the same power as full bolt on PRL cars on his page. Hopefully someone can give us more knowledgeable info
From THIS THREADYea I have Ktuner so iat1 is pre turbo, and sorry my man but my hotter pre turbo temps has not given me any hotter after Intercooler temps. Maybe in colder areas where ambient temps and under hood temps have a bigger difference it’d be a different story Idk I’m not an expert or anything I’m just trying to learn but “colder air in = colder air out” is definitely not true in my specific experience. Also I’m only comparing stock temps to map temps not necessarily true cold air intake temps to hot short ram temps. But my Intercooler is still cooling down to 8-15(during pulls only) above ambient I’m not sure how close to ambient cobra/injen users are getting?
I'd say restrictive stock airbox + prls awesome design with the MAF housingInteresting comments! It does bring up a lot of issues. One of the biggest evidence of the value of CAI intakes is the testing done by Derek Robinson.
http://prlarmy.com/Blog/innovative-motorworks-1-5t-intake-testing/
Why did the CAIs do so much better? Was it the stock intercooler or the restrictive stock airbox?
Lots of food for thought!
its always good to read what youve been up tooWent inside my garage to try to find a smaller sized air filter of the same type. Wanted smaller so the filter doesn't overwhelm the inside of the box. This sized filter will not block the pathway of the incoming air, that is coming in the PRL Cobra CAI hole. Just posting up for the visual.
Hitting the track tonight. Would love to test this setup out but I have some other testing to do. It actually may be better for me to test this the hotter it is outside. I can't leave it alone, I don't care if the intercooler is more efficient. My curiosity always kills me. So I'll get around to making this and testing as well as the Myxal WTF intake. Just for shi*s and giggles!
How are trims for you? Tried any afm calibrating?
Your standing starts i think the car should learn in better the more your attempting them.
When is the last time you flashed or disconnected the battery?
