Mystery dash rattle driving me crazy
  1. ionlybuyjapcar
    ionlybuyjapcar New Member
    Oct 18, 2018
    Australia
    Civic Hatch 10th Gen VTi-LX
    #61 ionlybuyjapcar, Oct 18, 2018
    I had similar rattle around the center speaker. The rattle isn't from the speaker, it is very tightly locked in the dash with 5x metal clips. The rattle is from the dash itself vibrating. I fixed it by sticking 2 pieces of 5cm felt tape under the dash so it is resting against the dash internals. Took me a good couple of hours to remove the speaker and find the source of the rattle. Very difficult to remove the speaker and you could damage the dash material.
  2. ionlybuyjapcar
    Oct 18, 2018
    Australia
    Centre of the dash. I think only the touring or LX version in Australia have the dash speaker. Knock around the area and do it again when pressing down the dash to hear the different.
    If you do not have the center dash speaker, it is unlikely you will have this problem. I think the cut out from the dash weakens the structure integrity of the dash.
    Another common area is the A pillars, it is a easy fix I think anyone could do it. Just remove the tab with "air bag text" and remove the screw holding the plastic piece. Put some tape foam or felt on the bottom area of the piece and not to high to obstruct the curtain airbag. Put some on the white electrical connector, about 10mm thick.
  3. sixhundredcc
    sixhundredcc Member
    May 14, 2017
    TX
    17' civic hatchback
    #63 sixhundredcc, Oct 18, 2018
    My hatchback doesn't have a center speaker. Was the dash rattling at the top or near the bottom? You had to go through the speaker for this?
  4. sixhundredcc
    sixhundredcc Member
    May 14, 2017
    TX
    17' civic hatchback
    Both a-pillars have already been fixed with felt installed by service. I have almost given up because two dealers have been unhelpful fixing the rattle
  5. ionlybuyjapcar
    Oct 18, 2018
    Australia
    It is around the area I highlighted in red where I put the felt under the dash. My car is right hand drive, could be a different area for left hand drive.
  6. civicdota
    civicdota Senior Member
    Jun 14, 2017
    99
    Toronto, ON
    2017 EX-T Sedan
    I wish I had a speaker to prop out and be able to reach into the dash. I'd probably stuff a pillow in there if I could in hopes to suffocate all the rattling.
  7. sixhundredcc
    sixhundredcc Member
    May 14, 2017
    TX
    17' civic hatchback
    Id rather get rid of the entire dash. but I don't have time or patience for that
    civicdota thanked this.
  8. civicdota
    Jun 14, 2017
    99
    Toronto, ON
    2017 EX-T Sedan
    I guess you can't have dash rattles if there is no dash hahaha.
    sixhundredcc thanked this.
  9. sixhundredcc
    sixhundredcc Member
    May 14, 2017
    TX
    17' civic hatchback
    Nope haha. My current remedy is to listen to music to drown out the rattle till I find another car to buy and dump this headache
  10. sixhundredcc
    sixhundredcc Member
    May 14, 2017
    TX
    17' civic hatchback
    Does anyone have an update ? My hatchback still has this intermittent noise. Not every time I drive it it happens which is strange
  11. pclaro143
    pclaro143 New Member
    Oct 11, 2019
    Portugal
    Honda Jazz
    Hi all,
    Almost one year has passed and guess what... I have a Honda Jazz/fitt with the exactlly the same issue as described and after 1 month trying to identify the issue I was able to "fix it"
    The funny thing is that i have the car for 6 year now and never had it before, the issue only appeard like 6 months ago.
    Now thinking back, it makes some sence as it matched the time my Jazz was recalled for a passanger Airbag replacment.
    So, my noise, although it sounded like comming from behing the air vents, comes from one of the 2 bolts holding the upper glove box compartment door. The bolt tightens to a king of u shaped metal holder, and looks like the screw, after the airbag replacment is not securing properlly.
    Hope it helps
    Pclaro
  12. Plezor
    Plezor Member
    Mar 14, 2018
    Australia
    Civic RS sedan 2016
    How do you remove the centre speaker?
