Mystery dash rattle driving me crazy
  1. SDSport6MT
    SDSport6MT Member
    Apr 20, 2018
    45
    San Diego
    2018 Civic Sport 6mt
    So since I've had the car now just over 3k miles I've had a vibration noise that sounds like something vibrating in the dash behind the radio. It only happens right over 2k rpm and is very audible in the cabin, hot or cold doesn't seem to change when it happens. I've pulled the radio out twice to try to locate it and initially thought it was the vent ducting vibrating on itself. Now that I've done the tear down twice I am almost certain it is the cabling vibrating against the vent duct which is behind the radio. The noise is plastic on plastic and the cables have a plastic sheath on them. Anyone else have a similar issue? I'm going to pull it apart again and add some kind of padding.
  2. latole
    latole Civic Lx 2018 Manual , Civic LX 2016 Manual
    Apr 13, 2017
    1,960
    437
    Vaudreuil,Quebec ,Canada
    I'm not expert , did you look at your cabin filter ?
  3. calonzo
    calonzo Senior Member
    Feb 13, 2017
    556
    117
    New Haven, CT
    2016 Honda Civic Touring, 2007 Honda Civic Hybrid
    There have been many posts about rattles. Not sure if there are any like yours, but probably there are. I vaguely remember one that was due to the windshield washer spray bar that rattled that seems to be in the same area you are talking about.
    https://www.civicx.com/search/115883155/?q=rattle&o=date&c[title_only]=1
  4. OP
    SDSport6MT
    SDSport6MT Member
    Apr 20, 2018
    45
    San Diego
    Had no clue this was in the glove box area, I'll take it out on my way home today and see if that solves it. If it ends up being that simple I will feel really silly :mad:
  5. latole
    Apr 13, 2017
    1,960
    437
    Check under dash for loose unused electric cable .
  6. OP
    SDSport6MT
    SDSport6MT Member
    Apr 20, 2018
    45
    San Diego
    Ok so it wasn’t the cabin air filter which I will be replacing soon because it was filthy. But the noise is obviously coming from the left of the glove box opening which leads to directly behind the radio. I can almost touch it from the glove box but it’s just out of reach.
  7. OP
    SDSport6MT
    SDSport6MT Member
    Apr 20, 2018
    45
    San Diego
    I’ve been searching every thread I can find and everyone seems to have a rattle from the actual air duct which I thought was the cause and it ended up not fixing it. Seems to be slightly more noticeable on a cooler morning and when the rpm drops from 2.5k to 2.1k. This is definitely something resonating inside the dash. It’s always at the same rpm that it is loudest then it fades quickly.
  8. calonzo
    Feb 13, 2017
    556
    117
    New Haven, CT
    Let us know if you figure it out!
  9. latole
    Apr 13, 2017
    1,960
    437
    Do you have the rattle with fan OFF or it do not mather ?
  10. fitter_here
    fitter_here Senior Member
    Apr 2, 2016
    393
    146
    Ste-Anne-des-Plaines, Quebec, Canada
    Civic LX 2016 Sedan
    I had similar noise/vibration coming from around the glove box compartment.
    I loosened the two(2) screws holding the glove box door, close the door by pushing firmly on the glove box door while tightening the screws.
    It fixed my problem.
    Good luck, I hope it fixes yours.
  11. OP
    SDSport6MT
    SDSport6MT Member
    Apr 20, 2018
    45
    San Diego
    Fan on or off it still happens.
  12. OP
    SDSport6MT
    SDSport6MT Member
    Apr 20, 2018
    45
    San Diego
    Thanks for the suggestion but this is happening with the glovebox detached still.
  13. OP
    SDSport6MT
    SDSport6MT Member
    Apr 20, 2018
    45
    San Diego
    Here is a video clip with the noise, the car is stopped in neutral and revving just over 2.5k then letting the rpm drop.
  14. latole
    Apr 13, 2017
    1,960
    437
  15. civicdota
    civicdota Senior Member
    Jun 14, 2017
    99
    Toronto, ON
    2017 EX-T Sedan
    Post update if you find yours, I have a CVT that rattles at 1650-1850 (this is the RPM that everything in the car resonates the most for) on cooler days in the dash. Sounds like its coming near the middle behind console/radio but it's hard to tell. Couldn't figure it out for many months and it doesn't always happen which is the mind boggling part.
