Mishimoto Oil Catch Can
xdecemberguy
Randrew
Honda Civic Type R
Just installed the Mishimoto oil catch can on my CTR and now I hear a slight rattle when taking off..anyone else notice
this noise also?
Nick
Las Vegas
18 Civic Type-R #12307, 98 Integra Type-R #0425, 07 Pilot EX-L, 17 Pilot Elite
It is the bracket rattling against the firewall. People, including myself, used insulation foam to place in between the bracket and firewall.
Honda Civic 10th gen Mishimoto Oil Catch Can AE532A44-363E-44AD-A691-93E68E37E58E
bobafettm
Metro Detroit, MI
2006 Lotus Exige; 2018 & 2021 Honda Type R
You can use the same stuff around your doors to get rid of rattles also ;) it’s essential for Type R ownership!
Honda Civic 10th gen Mishimoto Oil Catch Can 14CB32F2-2A7F-4BF8-8255-D7E11CF1CEB6
SCOPESYS
Geoff
MD
But it looks TERRIBLE !!!
There must be a better, more Cosmetic solution ?
Higgo8
Steve
Stoke-on-Trent
2017 FK8 CTR GT
Surely the door seal should sit against the frame? This would not rattle seeing as it's a rubber/foam seal...
JSmoothBui
Jims_CTR
Jimmy
Laurel, MD
2018 Honda Civic Type R - 16626 - Championship White
Is there a picture of where you installed this?
davidgostbo
Texas
Honda Civic Ex-t 2016
this noise also?
I used to have this, it only occurs when you press on the gas right? And if you let off gas goes away? If it is your baffle or the brass fitting is loose. Tap on that brass holes they shouldn’t move, if it does that’s your problem
98-0425
Nick
Las Vegas
I don't have a picture. Just sandwich this foam between the bracket (side facing the firewall) and the firewall.
mnksauce
Bay Area
2018 Civic Type R, 2005 RSX Type S
When I installed mine, I used foam and still had the rattle.
I found that my rattle was from the silver disc on the inside, so it was pretty much a self contained rattle inside the catch can. I feel that it was partially my fault as I found oil around the plastic fitments. Read through some other posts related to the catch cans in general and opted to replace the fitments with brass ones and I think the correctly pressurized catch can held the silver media in place correctly.
https://www.civicx.com/threads/rattle-when-pressing-the-accelerator.21880/page-3#post-424155
I've since emptied the catch can more than a few times by just unscrewing the reservoir and the noise hasn't come back.
Good luck!
