Florence_NC
- Sep 25, 2018
- 2
- 340
- 220
- North Carolina
- 2018 Type R
As someone with practical vehicle aero experience, I question the accuracy of your assessment of the brake duct function. Modern OEM vehicle design is all about efficiency, especially aero efficiency. Nothing gets to ride on a modern vehicle for free. If it is not accomplishing something, then it doesn't get a spot on the bus.All great questions!
So for the brake ducts, Honda put a ton of work into their aero to make sure that the airflow is going where it needs to go. The duct there is already forcing it into the factory ducting and out through the wheel well into the brakes. With that duct removed there's still enough of a pressure differential on the inside of the wheel well generally from the wheel spinning, and also thanks to the belly pan, that the airflow is still being pulled through there. Our bracket works as more of a guide for this airflow to make sure that it's still being pushed through the cooler. Though, it definitely would've been nice of Honda to give us a larger opening on that section of the bumper from the factory, but from what we've seen, there's still plenty of cooling air pushing through there.
-Nick
An opening in the front of a vehicle cost drag, so you can bet that the OEM did not place that opening there for nothing. Honda placed that brake duct there, with a decreasing cross-sectional area, to create a jet of air pointed at the front brake assembly. There is an additional turning vane on the steering knuckle to help direct that jet to its desired point of interaction. Honda did not spend either the financial capital nor the efficiency capital in this design for nothing. It was there for a reason, and removing it must reduce the function of the system at some level.
And while I agree that, with the duct removed, the natural high pressure area in front of the vehicle and the low pressure area inside the wheel well will still induce air movement. But there is no way possible that it is at the same volumetric flow rate as with the duct in place. It is just not possible.
Plus, the air that is passing through the duct opening is now preheated by the oil cooler, further diminishing the effectiveness of the brake cooling. It is not likely that this extra heat has a big effect since the brake temps are so much higher than the oil cooler temps, but when a system is functioning near its threshold, small changes can create tipping points in a systems functionality. So it can't be automatically ruled out that this could have a negative effect.
