Miles done on lowering springs
funfun789
Kevin
Texas
2016 Honda Civic
I'm curious about how many miles some 10th gen Civic owners have driven on stock shocks and if it has been blown or not. I am currently on Godspeed springs with 22k on the shocks and installed at 20k.
tgastte
tristan
socal
2018 civic si
I'm at 13k but I put on skunk2 at 200 miles then changes them to D2 , still no problems...knock on wood
Honda Civic 10th gen Miles done on lowering springs 5E0BDF15-476A-4FA3-BAA2-7FEF64B067D0
Honda Civic 10th gen Miles done on lowering springs D0D0FC2F-41CD-4715-AEC0-0402C90ABC15
Joshr2019
Josh
16 civic LX MT
Question about the srings. I have stock tires for my LX on aftermarket rims and was wondering how low I could go with the 215/55 size.
funfun789
funfun789
Kevin
Texas
2016 Honda Civic
You could do with any springs you like even if it's the lowest one. It's just a matter of how much drop you want. I'm running 18x8.5 with 225/40. Will be upgrading to 245 when I need new tires.
Joshr2019
Josh
16 civic LX MT
Ok so I was looking at D2 springs. Could I put those on without any rubbing and have a full car. Again using the factory size tires. Only reason I want to stick with that size is because I put the stock steel rims with winter tires that are also the 215/55 16. Has to be useful in the winter here as well
Joshr2019
Josh
16 civic LX MT
What size tires and rims are you using and what springs did you use
funfun789
funfun789
Kevin
Texas
2016 Honda Civic
Are you running aftermarket springs or OEM springs now?
funfun789
funfun789
Kevin
Texas
2016 Honda Civic
I'm pretty sure you're good considering the tires you are running with tuck behind the fender
